U-Boot, video console, and visual artifacts
My apologies for the delayed response.
(07-17-2021, 08:01 AM)pkubaj Wrote: we previously talked on IRC about how I don't get a display. I use Gentoo with Manjaro kernel 5.11.16 and that works, but using even vanilla 5.11.16 fails to display anything. I found that using I have to use two Manjaro patches to get display working and they are still present in Manjaro's repo:
https://gitlab.manjaro.org/manjaro-arm/p...hack.patch
https://gitlab.manjaro.org/manjaro-arm/p...tcpm.patch
I'm not sure how the screen behaves on 5.13, my experience is with 5.11.16. I'm now planning to upgrade to 5.13. I use uboot 2021.07.
Thank you very much for providing this feedback!  I've had a rather detailed look at those two patches, but I'm still not exactly sure why are they required to make the video output work.  I'll have another look at that.
(07-19-2021, 07:22 AM)zackw Wrote: I investigated the scary-looking message about a bad SPI CRC checksum; it turns out to be unrelated and harmless.  It just means that there isn't any U-Boot configuration stored in the SPI flash.  Unfortunately I don't think it can be gotten rid of except by moving the entire bootloader into the SPI, or by code changes to U-Boot. See https://lists.denx.de/pipermail/u-boot/2...53338.html (no response, alas)
Right, that's a rather benign error message, as I've already explained in one of my earlier posts.
RE: U-Boot, video console, and visual artifacts - by dsimic - 07-28-2021, 09:37 AM
  uboot wont boot to SD card after upgrade jbradley419 7 815 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 288 01-16-2024, 09:17 AM
Last Post: jbradley419
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,594 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,222 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 686 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 584 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,173 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,867 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 799 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,936 06-14-2023, 07:20 AM
