Pinecil died after first use, housing gets very warm plugged into USB
(06-06-2021, 03:30 AM)barray Wrote: When powering you should leave the tip connected I believe - otherwise if it is trying to heat the tip it's got nowhere but the handle to dissipate it.
Unless it works unlike all the other soldering irons in that form factor that should be wrong. The heater is part of the tip, so if it isn't connected there's no current running through it and therefore (almost) no power converted to heat.
(06-06-2021, 03:30 AM)barray Wrote: You should take it out of the housing and figure out where the heat is coming from - I would expect to see a chip getting pretty hot under that plastic cover - should be obvious with your thermal camera.
Yeah that'd be interesting. Considering it still works in DFU mode I expect the main processor is still okay, I suspect a driver/transistor has failed closed (they like to do that, MOSFETs especially). That would explain the heat (and might be easily repaired).
RE: Pinecil died after first use, housing gets very warm plugged into USB - by Kaythe - 06-10-2021, 01:56 AM
Question Can Pinecil Read USB-C Cable E-Marker Chips? Garywoo 0 32 04-23-2024, 01:48 PM
Last Post: Garywoo
  Connecting a power supply to the Pinecil jon_bondy 1 387 02-29-2024, 07:37 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 797 01-31-2024, 12:34 AM
Last Post: suga7
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 374 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 8,319 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 671 11-02-2023, 09:11 AM
Last Post: Harrysteed
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,304 10-09-2023, 10:10 PM
Last Post: clemon79
  PD resets during heat up tip [Pinecil V2] Neitron4ik 2 1,557 10-09-2023, 01:22 AM
Last Post: Neitron4ik
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,458 02-02-2023, 11:45 AM
Last Post: VaZso
  Brand new Pinecil v2 won't boot on PD jhutch 1 2,264 12-14-2022, 01:03 AM
Last Post: River
