? vpn or tor for mobian
(11-05-2021, 04:51 AM)wibble Wrote:
(11-04-2021, 02:30 PM)tmp201 Wrote: Could anyone here please link, or write a quick step by step guide to on how to install a VPN on mobian? Thanks!
If you want more specific instructions than the ones provided above you'll have to be more specific about your requirements. What sort of VPN and for what purpose? For example I use wireguard to connect to my home network when I'm out, which has a very different configuration process to using OpenVPN to connect to a commercial provider.
Hi sorry i lost my login.. I'm writing from here now. I can use the best security. Wireguard or openVPN. Which is the best one? please link some guide. Thanks!
? vpn or tor for mobian - by rvh - 04-22-2021, 06:44 AM
RE: ? vpn or tor for mobian - by nas - 04-22-2021, 11:13 AM
RE: ? vpn or tor for mobian - by MtnSk8 - 04-23-2021, 07:25 PM
RE: ? vpn or tor for mobian - by tmp201 - 11-04-2021, 02:30 PM
RE: ? vpn or tor for mobian - by wibble - 11-05-2021, 04:51 AM
RE: ? vpn or tor for mobian - by 74vscsa2uu - 11-07-2021, 07:21 PM
RE: ? vpn or tor for mobian - by wibble - 11-08-2021, 04:11 AM
RE: ? vpn or tor for mobian - by 74vscsa2uu - 11-13-2021, 12:46 PM
RE: ? vpn or tor for mobian - by 74vscsa2uu - 11-27-2021, 08:55 PM
RE: ? vpn or tor for mobian - by b7l3wui26r - 12-02-2021, 05:58 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,067 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Mobian PIN changed after update! Mwo87 21 17,949 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 4,282 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  No sound after Mobian upgrade arbocenc 1 787 11-28-2022, 11:02 AM
Last Post: arbocenc
Exclamation No wIfI after Mobian update crakabeats 3 2,163 11-03-2022, 04:16 AM
Last Post: wifinoworkie
  pinephone-support package not upgradable on Mobian fhireman 4 2,422 09-24-2022, 08:01 AM
Last Post: dante404
  PinePhone running Mobian - Malware extraction? names_fold 1 1,655 01-24-2022, 12:00 PM
  Mobian updates for phosh steves 2 2,123 01-17-2022, 02:18 AM
Last Post: bcnaz
  Assists for running Mobian my PinePhone gilwood 0 1,606 01-01-2022, 04:38 PM
Last Post: gilwood
  Just reflashed to latest mobian, it never asked for disk encryption? JuniperFury 3 2,290 10-18-2021, 10:24 AM
Last Post: JuniperFury
