Mobian can't see OpenVPN is installed.
(03-11-2021, 08:36 PM)C0ffeeFreak Wrote:
(03-11-2021, 06:56 AM)wibble Wrote: Native or flatpak? The readme mentions the '--debug [LEVEL]' command line option or an environment variable to set, which is easy for a native install but I don't know how it works for flatpak.
https://github.com/jkotra/eOVPN
The code getting the version is here:
https://github.com/jkotra/eOVPN/blob/mas...openvpn.py
See get_version(self) at line 172. It's trying to run 'openvpn --version' and find the version in the output using a regular expression. Is it unable to run the command (no openvpn in the path, sandboxing preventing it running, something else?) or does the response not contain a matching string? Or is there some other problem like a missing python library that's getting hidden by error trapping?
Thanks, I have been through all the debugging. No joy. I gave up.  I purchased a subscription to ProtonVPN for a year to use on the Pinephone when I am running Mobian. That app is fairly new. I will pass that bug on to the developer and let him see if he can figure it out. Somehow the file system must be different although I couldn't find it or something is missing in Mobian. There are files for OpenVpn everywhere throughout the system.
C0ffeeFreak: Did you install the ProtonVPN app? I tried, but my ethernet connection broke just after the repository install. I didn't even get to the main app install. I tried to disable the kill switch, but it did not recognize the command since the main app was not installed yet. I deleted everything and my ethernet connection came back up. I have the new Bookworm edition of Mobian, but I have tried it on the previous version with the same results. Thanks for any advice.
RE: Mobian can't see OpenVPN is installed. - by county93 - 10-03-2021, 04:10 PM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 65 23,155 07-12-2025, 07:46 AM
Last Post: anonymous
  cryptocurrency on mobian/pinephone biketool 33 50,123 06-30-2025, 02:57 PM
  XLibre for Mobian Hiraghm 1 247 06-30-2025, 01:38 AM
Last Post: Haroldkent
  Axolotl on PinePhone / Mobian arno_nuehm 223 242,431 06-25-2025, 01:19 PM
  VoIP account on mobian dialer j_s 0 165 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 348 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 718 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 787 04-29-2025, 02:10 PM
Last Post: mdk
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 872 01-15-2025, 08:08 PM
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 760 01-02-2025, 12:47 PM
Last Post: zetabeta
