Mobian Issues
(02-15-2021, 07:40 PM)Csanderson0313 Wrote:
(02-15-2021, 04:47 PM)C0ffeeFreak Wrote:
(02-15-2021, 03:40 PM)Csanderson0313 Wrote: One of the biggest issues that I see with the software is that I can not make calls. When I go to make a call, It will hang right up. Anyone else having an issue with calling or how can I fix this?
Thank You
Chris
Are you running the latest updates? There was a new call manager update today.
The best way to upgrade is from the terminal.
sudo apt-get update && sudo apt-get upgrade
Thank You
Chris
Also make sure your APN is set correctly. VoLTE will fail and cause the same problem if it's not.
Thank You Guys. The APN looks to be correct. Im downloading the update now to try it.
I upgraded it but now it will not take my password to unlock the phone. Did the password changed? what is the new password to unlock?
Thank You
Chris
Mobian Issues - by Csanderson0313 - 02-15-2021, 03:40 PM
RE: Mobian Issues - by C0ffeeFreak - 02-15-2021, 04:47 PM
RE: Mobian Issues - by Csanderson0313 - 02-15-2021, 07:40 PM
RE: Mobian Issues - by Csanderson0313 - 02-16-2021, 05:04 AM
RE: Mobian Issues - by MtnSk8 - 02-16-2021, 11:16 AM
RE: Mobian Issues - by Csanderson0313 - 02-16-2021, 01:26 PM
RE: Mobian Issues - by C0ffeeFreak - 02-16-2021, 05:59 PM
RE: Mobian Issues - by dcinoz - 02-16-2021, 08:46 PM
RE: Mobian Issues - by C0ffeeFreak - 02-15-2021, 11:38 PM
RE: Mobian Issues - by dcinoz - 02-18-2021, 06:05 AM
RE: Mobian Issues - by theD0ctor - 03-01-2021, 05:28 PM
RE: Mobian Issues - by C0ffeeFreak - 03-01-2021, 05:44 PM
RE: Mobian Issues - by theD0ctor - 03-01-2021, 06:16 PM
RE: Mobian Issues - by Gribouille - 03-02-2021, 04:57 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 21 2,153 3 hours ago
Last Post: anonymous
  Mobian repository status henrythemouse 16 8,829 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 140 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,022 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,841 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 643 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,944 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,911 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 638 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,045 06-19-2023, 03:02 PM
Last Post: vusra
