Minimum daughter boards/peripherals required for main board to boot
Let's narrow down what causes changes. By making changes one at a time, and carefully noting what happens, one can almost always find what works and what doesn't, even with multiple hardware failures.
Right now, you get an orange LED for two seconds, then nothing.
If you reinstall the battery (remove the bypass!) does this change?
If not, reassemble everything. If nothing changes, let's next assume the PBP hardware is all working. Why? Because numerous people (including myself) have had the exact same symptoms at one time or another, due to corrupted software, and/or SD cards that don't play well with the PBP.
RE: Minimum daughter boards/peripherals required for main board to boot - by KC9UDX - 02-14-2021, 09:19 AM
  Replacement main board for Developers mozes 10 1,752 11-27-2023, 04:14 AM
Last Post: mozes
  unable to boot after manjaro update gega 6 3,178 10-28-2022, 01:18 PM
  Replacement board avaliability mrjay 1 2,442 07-06-2021, 04:08 PM
  How to boot from USB? kendew 7 12,428 10-08-2020, 07:06 AM
Last Post: Arwen
  Pinebook Pro Boot Issues - Booting needs multiple attempts mtndew 13 17,453 10-04-2020, 08:55 AM
  Upgrade eMMC card - boot problems alpopa 0 2,281 09-16-2020, 12:31 PM
Last Post: alpopa
  Reboot, and halt and boot, are not the same regivanx 0 1,954 09-14-2020, 02:20 PM
Last Post: regivanx
  PBP not booting screen blank after SD card boot Jakobp 10 13,718 08-18-2020, 08:56 PM
Last Post: trinapicot
  m.2 adapter board screw missing? screamy 4 6,113 07-01-2020, 08:37 PM
Last Post: screamy
  Boot problems with new 128GB eMMC module Kareema 1 3,310 05-31-2020, 10:36 AM
Last Post: Kareema
