(potential) work-around for Playstore authentication issue
#27
(07-25-2016, 10:41 AM)jonsmirl Wrote: I'm hitting the Google Play auth bug all of the time too. This is very annoying and it needs to be fixed ASAP.
As a work around, this has worked for me every time.
Once it fails, go into Settings/Accounts.
Click on the Add Account Google item to add a new account
type your existing Google account into this new account
that will generate an error saying it is already registered
now it will work again for a while....
wash rinse repeat....
Tried this just now and it works..a royal pita to do it every time, but if it is a consistent workaround, as sad as the idea may be that one has to do this every time, its better than nothing.
I remain somewhat amazed that this issue hasn't been fixed by now.
RE: (potential) work-around for Playstore authentication issue - by DonFL - 07-28-2016, 02:48 PM
  USB GPS dongles that work with Android on Pine64+ ? trondkj 2 4,514 11-16-2017, 02:14 PM
Last Post: Skivholme
  Playstore Selections Limited in 7.1 TV CharlieB 2 3,563 10-19-2017, 12:24 PM
Last Post: Luke
  Does snapchat work on pine64 with android? user875545 1 4,260 08-29-2017, 12:05 AM
  VPN issue on Pine64 pinea64.edison 4 6,571 06-27-2017, 12:25 PM
Last Post: milkaca
  No Intenet Access Need Help Diagnosing Underlying Issue Bob123456789 10 11,353 06-02-2017, 01:32 PM
Last Post: Bob123456789
  anyone make pine64 lcd hdmi work simultaneously bokeer 4 7,078 12-11-2016, 05:57 PM
Last Post: Luke
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 24,276 10-29-2016, 04:31 AM
Last Post: joe
  pine64 a piece of work water 4 6,026 10-28-2016, 07:41 AM
Last Post: jkmooney
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 5,685 10-17-2016, 11:42 AM
Last Post: mathiraj
Sad Airmouse doesn't work on any Android ameth 0 2,641 09-11-2016, 06:29 AM
Last Post: ameth
