(potential) work-around for Playstore authentication issue
(06-08-2016, 12:29 PM)Danja Wrote:
(06-08-2016, 06:55 AM)Luke Wrote: All credit goes to Keex
At the moment this is a potential work-around for the issue since I do not have a spare Pine64 to reproduce the issue. So if you are experiencing this problem please leave feedback below if this solution worked.
Keex wrote:
"Haven't read the whole thread, but I encountered a problem with the Playstore before.
The problem was the System Time. The Pine doesn't have a real time clock, and obviously doesn't get the time from the carrier (like smartphones). Hence it's just set to some random value a few years ago.
In my case I couldn't use the playstore (or any other Google apps for this matter). After I set the system time correctly, the apps worked fine. In the end I used an app that set the system time after booting automatically (requires root)." (original post
This didn't work for me, but what does work is if I go to the accounts page and attempt to add a new account using the same email as my existing, it will error and tell you that the account already exists on the device and then allow me to install things again.
Darn it :/ I thought we had a reliable temporary solution. Just for reference - could you write precisely what you did with the clock: manually set current time and date ?
RE: (potential) work-around for Playstore authentication issue - by Luke - 06-08-2016, 03:19 PM
  USB GPS dongles that work with Android on Pine64+ ? trondkj 2 5,422 11-16-2017, 02:14 PM
Last Post: Skivholme
  Playstore Selections Limited in 7.1 TV CharlieB 2 4,275 10-19-2017, 12:24 PM
Last Post: Luke
  Does snapchat work on pine64 with android? user875545 1 5,048 08-29-2017, 12:05 AM
  VPN issue on Pine64 pinea64.edison 4 7,660 06-27-2017, 12:25 PM
Last Post: milkaca
  No Intenet Access Need Help Diagnosing Underlying Issue Bob123456789 10 14,017 06-02-2017, 01:32 PM
Last Post: Bob123456789
  anyone make pine64 lcd hdmi work simultaneously bokeer 4 8,345 12-11-2016, 05:57 PM
Last Post: Luke
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 28,664 10-29-2016, 04:31 AM
Last Post: joe
  pine64 a piece of work water 4 7,136 10-28-2016, 07:41 AM
Last Post: jkmooney
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 6,452 10-17-2016, 11:42 AM
Last Post: mathiraj
Sad Airmouse doesn't work on any Android ameth 0 2,992 09-11-2016, 06:29 AM
Last Post: ameth
