i2c-bus kernel modules
Hi, sorry for the late reply.
Unfortunately i couldn't figure it out, since i overwrote the SD card. But it coul well be that I screwed the image up somehow. There were several problems, that made me go into the config files. I was pretty sure I haven't touched anything i2c related, but maybe i accidentally did. It is very unstatisfying not to know the reason, but the new image worked out of the box.
Generally, i think the images on pine64.pro are more up to date, than the ones on the wiki, but that might just be my impression, and should be irrelevant, since i updated the kernel every time.
It was not an connection issue, since I used the same cables both times, but you are right, that is generally something to look out for.
i2c-bus kernel modules - by robertvaldimarsson - 06-02-2016, 02:42 PM
RE: i2c-bus kernel modules - by martinayotte - 06-03-2016, 07:47 AM
RE: i2c-bus kernel modules - by martinayotte - 06-03-2016, 09:16 AM
RE: i2c-bus kernel modules - by martinayotte - 06-03-2016, 01:49 PM
RE: i2c-bus kernel modules - by martinayotte - 06-03-2016, 03:06 PM
RE: i2c-bus kernel modules - by dkryder - 06-03-2016, 05:32 PM
RE: i2c-bus kernel modules - by martinayotte - 06-03-2016, 03:48 PM
RE: i2c-bus kernel modules - by martinayotte - 06-03-2016, 06:04 PM
RE: i2c-bus kernel modules - by martinayotte - 06-03-2016, 08:13 PM
RE: i2c-bus kernel modules - by peterz - 06-07-2016, 01:01 PM
RE: i2c-bus kernel modules - by robertvaldimarsson - 06-07-2016, 01:48 PM
  (ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release lenny.raposo-pine64.pro 259 557,054 05-21-2018, 06:30 AM
Last Post: Luke
  how to set kernel parameter 'fsck.mode=force' marcelser 6 15,024 05-09-2018, 09:07 PM
Last Post: pfeerick
Question Debian Jessie with 4.x.y kernel and complete hardware support? Spark 2 7,111 04-24-2017, 09:56 PM
Last Post: Spark
  Adding a missing kernel module spz2k 8 14,907 01-10-2017, 06:22 AM
Last Post: xalius
  NIC not visible after kernel update xleon 1 4,042 11-15-2016, 05:23 PM
Last Post: xleon
  [OUTDATED] Debian Jessie (4.7.0-rc1 Kernel) Images fire219 4 19,257 07-20-2016, 02:36 PM
Last Post: umiddelb
  How to install modules into system? MicroDiery 6 10,136 05-27-2016, 06:44 PM
Last Post: JamesHarris
  Debian kernel upgrade question jl_678 2 5,842 04-18-2016, 05:54 PM
Last Post: jl_678
