Would you like to see and buy the 2.2 revision?
Yes, please!
91.67%
55
No, thank you
8.33%
5
60 vote(s)
PineBook Pro revision 2.2: Wishlist for the hardware issue fixes
#80
(07-28-2021, 05:46 AM)dsimic Wrote:
(07-10-2021, 06:58 AM)KC9UDX Wrote: That button should be a switch, and all the switches should be accessible without removing the bottom cover.
I'd just add this...  When my PineBook Pro is somewhere outside my home, I wouldn't like all the switches to be available with the back cover in place, because that would allow anyone to mess with those if I leave the laptop unattended.  Thus, it would be the best to have two variants of the back cover available: end-user variant (with no access holes) and developer variant (with the required openings to access the switches).
(07-14-2021, 05:17 AM)jpalus Wrote: Overheating is the major issue overall I'd say. From time to time I'd get random freezes during load, but it became unbearable recently when ambient temperature started to hit 28C during summer. I've bought one of those nonsense "laptop cooling pad" to see if it makes any difference and boy it does. No freezes ever since, I can video call on web skype for hours (almost 100% freeze reproducer before) with battery charge not falling below 88%. Mind that I'm running stock CPU frequencies by now (stock as in RK3399 stock: 1.8GHz).
The back cover of the PineBook Pro is made of rather thin metal, to save weight, but that creates an undesirable hot spot where the RK3399 touches the back cover and makes cooling worse.  Thus, it should be possible to improve the passive cooling in the PineBook Pro by affixing a piece of 2-3 mm thick aluminum sheetmetal to the inside of the back cover, which has already been demonstrated by one of the forum members.  That should eliminate the hot spot, turning a much larger area of the back cover into a passive heatsink and improving the cooling.
This cooling improvement is one of my future projects. Cool
(07-14-2021, 11:26 AM)jiyong Wrote: 1.8 GHz might be a bit too much for the RK3399, but in my Samsung Chromebook Plus (also with RK3399 and passively cooled) I only noticed a lot of heat when running Rosetta@Home. When playing the Android game Riptide GP, there's hardly any heat.
You can always apply CPU thermal throttling, which I always keep configured.  It would be interesting to see what CPU frequencies end up being used in the RK3399-based Samsung Chromebook Plus under light and heavy load.
The heat problems of Raspberry4 have also been solved by adding a big metal sheet within the Raspberry400.
RE: PineBook Pro revision 2.2: Wishlist for the hardware issue fixes - by Juergen - 08-19-2021, 10:19 AM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 726 05-06-2024, 09:27 AM
  New Hardware names_mark_ 1 257 04-23-2024, 08:41 AM
Last Post: dachalife
  Pinebook Pro on Debian 12 Power Issue u974615 1 376 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 322 02-17-2024, 07:06 PM
  Pine Dock Networking Issue trillobite 1 302 02-10-2024, 12:03 AM
Last Post: trillobite
  Pinebook Pro charging issues tomekdev 1 661 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,163 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,574 09-13-2023, 03:43 AM
Last Post: k3dAR
  Hardware makes a strange pop noise. Gemeindepirat 7 3,084 08-12-2023, 01:59 AM
Last Post: User 27258
  PineBook Pro dead ottahe 9 6,116 01-18-2023, 07:41 PM
Last Post: ottahe
