New Hardware
Hello!
I've been considering getting myself a Pinebook Pro, but I check again every year or so and the hardware hasn't been updated it seems. Are there any plans for 8GB RAM or a newer ARM CPU?
Cheers!
You can get the PT2 with 8gb Ram & RK3566.
BT & WIFI are not enabled by default as with the PBP though. It can be a daily driver, if you take the time to set it up correctly and there is ample information to do just that.
It is not for everyone yet, as WIFI may occasionally cause the system to hang at shutdown and BT has to be manually enabled for it to work reliably; It really depends on what you plan to use it for and your Linux experience.
With that disclaimer stated, I’m using mine weekdays with a mobile router/Linux hotspot and JBL BT external speaker. Due to the smaller form factor & back-lit keyboard, I find myself using it more than my PBP most days, unless I am going to be tethered to a desk.
PinePhone, Pinebook Pro & PineTab2 owner.
Though laptops and tablets are not the same thing... not even comparing touchscreen laptops with keyboard-attached tablets.
Aside from the different form factor, the Pine Tab 2 only has a 10" 800p screen vs the PineBook Pro's 14" 1080p screen.
  Hardware makes a strange pop noise. Gemeindepirat 7 10,118 08-12-2023, 01:59 AM
Last Post: User 27258
  Pinebook Pro malfunctioned hardware samtux 10 14,117 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 275,815 11-30-2022, 04:28 PM
  Hardware shortcomings commiecam 14 21,035 01-30-2022, 09:04 AM
Last Post: moonwalkers
  Pinebook pro Hardware failure: how should I diagnose it? alxndr.psclt 5 9,604 09-08-2021, 09:03 PM
  hardware compatibility table in the wiki.. kernel version? speculatrix 1 8,444 09-09-2020, 08:06 AM
  PBP Hardware Issues zaius 16 32,206 04-27-2020, 12:00 PM
Last Post: zaius
  Which sound preference for "hardware" and "speaker" richfm 1 6,117 11-19-2019, 11:45 AM
Last Post: Watercourse
