Would you like to see and buy the 2.2 revision?
Yes, please!
91.67%
55
No, thank you
8.33%
5
60 vote(s)
PineBook Pro revision 2.2: Wishlist for the hardware issue fixes
#65
(07-07-2021, 07:35 PM)dsimic Wrote:
(06-12-2021, 04:05 AM)KC9UDX Wrote:
(06-11-2021, 06:02 AM)dsimic Wrote: That's a very good point!  The only issue could be the rather long distance between the PCB and the back cover, which would make it a bit hard to accurately poke the buttons using a pin or something similar, without accidentally touching something else on the PCB.  The buttons should be much closer to the back cover for the pinholes to work safely.
That is why the toothpick in our knife is non-conductive.  Big Grin
After removing the back cover of my ISO PineBook Pro a couple of times to use the switch that disables the eMMC module, your suggestion about drilling a few holes in the bottom cover seems increasingly more reasonable. Smile
If n is the number of times the cover gets taken off before I get annoyed enough to drill the holes, I must be at n-1  Smile
:wq
[ SRA accepts you ]
RE: PineBook Pro revision 2.2: Wishlist for the hardware issue fixes - by KC9UDX - 07-07-2021, 10:29 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 737 05-06-2024, 09:27 AM
  New Hardware names_mark_ 1 258 04-23-2024, 08:41 AM
Last Post: dachalife
  Pinebook Pro on Debian 12 Power Issue u974615 1 378 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 325 02-17-2024, 07:06 PM
  Pine Dock Networking Issue trillobite 1 305 02-10-2024, 12:03 AM
Last Post: trillobite
  Pinebook Pro charging issues tomekdev 1 661 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,165 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,691 09-13-2023, 03:43 AM
Last Post: k3dAR
  Hardware makes a strange pop noise. Gemeindepirat 7 3,095 08-12-2023, 01:59 AM
Last Post: User 27258
  PineBook Pro dead ottahe 9 6,142 01-18-2023, 07:41 PM
Last Post: ottahe
