Would you like to see and buy the 2.2 revision?
Yes, please!
91.67%
55
No, thank you
8.33%
5
60 vote(s)
PineBook Pro revision 2.2: Wishlist for the hardware issue fixes
#49
I've recently noticed that the screen on my PineBook Pro sometimes flickers a couple of times when I plug a USB 3.0 device (a Gigabit Ethernet dongle, to be precise) into the USB 3.0 port next to the barrel port for the charger.  It's like the screen backlight or the entire screen quickly turns off and back on a couple of times.  The screen continues to work just fine afterwards, as if nothing happened.
Upon further investigation, it seems that getting the USB 3.0 plug to lightly touch the USB 3.0 socket, so the internals of the plug touch the internals of the socket but without starting the actual mating of the connectors, triggers this issue.  The even more weird part is that it does not happen always, but when it happens, I can easily use the described way to make the screen flicker a few times in a row.
Has anyone else encountered this?
RE: PineBook Pro revision 2.2: Wishlist for the hardware issue fixes - by dsimic - 05-09-2021, 01:29 AM
  New Hardware names_mark_ 1 202 04-23-2024, 08:41 AM
Last Post: dachalife
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 548 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 346 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 290 02-17-2024, 07:06 PM
  Pine Dock Networking Issue trillobite 1 271 02-10-2024, 12:03 AM
Last Post: trillobite
  Pinebook Pro charging issues tomekdev 1 627 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,109 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 130,556 09-13-2023, 03:43 AM
Last Post: k3dAR
  Hardware makes a strange pop noise. Gemeindepirat 7 3,000 08-12-2023, 01:59 AM
Last Post: User 27258
  PineBook Pro dead ottahe 9 6,037 01-18-2023, 07:41 PM
Last Post: ottahe
