Would you like to see and buy the 2.2 revision?
Yes, please!
91.67%
55
No, thank you
8.33%
5
60 vote(s)
PineBook Pro revision 2.2: Wishlist for the hardware issue fixes
#35
I use Pinebook Pro as a main notebook for my work. I can recommend following improvements:
- Please make the touchpad better (it is the disadvantage of highest priority)
- It could be better to make the plastic a little bit thicker under and over usb slot.
- In general the case could be from metall (maybe it is possible to offer 2 options - from plastic and from metall) I would pay much more money for high quality case from metall.
- Right now the design of the case is like from Macbook where they make an optical ilusion that the body is thin. I think that for 'professional users' it is better to make the body thickness everywhere like at the beginning (where the monitor is mounted). And after the free space inside is possible to use for some diy boards or extensions.
One of the best think is that it is possible to charge from USB 5V 3A. Please keep this possibility!
RE: PineBook Pro 2.2 revision: Wishlist for the hardware issue fixes - by esud - 02-24-2021, 01:25 AM
  New Hardware names_mark_ 1 126 04-23-2024, 08:41 AM
Last Post: dachalife
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 529 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 331 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 275 02-17-2024, 07:06 PM
  Pine Dock Networking Issue trillobite 1 259 02-10-2024, 12:03 AM
Last Post: trillobite
  Pinebook Pro charging issues tomekdev 1 609 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,077 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 130,045 09-13-2023, 03:43 AM
Last Post: k3dAR
  Hardware makes a strange pop noise. Gemeindepirat 7 2,952 08-12-2023, 01:59 AM
Last Post: User 27258
  PineBook Pro dead ottahe 9 6,002 01-18-2023, 07:41 PM
Last Post: ottahe
