Would you like to see and buy the 2.2 revision?
Yes, please!
91.67%
55
No, thank you
8.33%
5
60 vote(s)
PineBook Pro revision 2.2: Wishlist for the hardware issue fixes
#98
(09-27-2021, 12:54 PM)KC9UDX Wrote: My reasons again for wanting to keep the barrel socket:
1) It's more durable
2) It's less proprietary (again, anyone with a lathe can make barrel plugs and sockets, who can make USB-C?)
3) It's capable of higher current, that is, higher power, without (problematic in my opinion) voltage-negotiation.
4) It doesn't transfer data.  There is no need to hack a cable to make sure that it can't transfer data.
5) It can be connected with individual conductors in an emergency.  Yes, really.  This simply can't be done with USB-A,-B,-C,-D,-whatever.
6) There isn't any licencing
I heavily disagree with some of these points.
I was unlucky enough to break my barrel charger (the cable). I have a power cord of a Netgear switch which has the same physical dimensions and is rated at the same voltage and amperage as the PineBook Pro charger. Yet, if I plug it in my PineBook Pro, it is not recognized, it doesn't charge.
If I want a barrel charger that is guaranteed to work, then I would have to buy it at the pine64.com store.
I tried bending it back into shape and cutting off the plastic. The plug doesn't fit anymore, but at least it does charge the PBP.
If the USB-C port worked up to specification, then I could have just replaced the charging cable with another USB-C cable.
The big problem is that the USB-C port on the PBP doesn't work as it should
- Power input is limited to 11.5W (not enough at full load)
- Power output is limited, causing some peripherals to fail.
- The socket is not rotation proof
All these things are mistakes on Pine64's side. I am all in favor of using USB-C in future products. It would make it easier to replace a charger cable like in my case.
RE: PineBook Pro revision 2.2: Wishlist for the hardware issue fixes - by maxjrh - 09-28-2021, 04:45 AM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 738 05-06-2024, 09:27 AM
  New Hardware names_mark_ 1 258 04-23-2024, 08:41 AM
Last Post: dachalife
  Pinebook Pro on Debian 12 Power Issue u974615 1 378 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 325 02-17-2024, 07:06 PM
  Pine Dock Networking Issue trillobite 1 305 02-10-2024, 12:03 AM
Last Post: trillobite
  Pinebook Pro charging issues tomekdev 1 661 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,165 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,748 09-13-2023, 03:43 AM
Last Post: k3dAR
  Hardware makes a strange pop noise. Gemeindepirat 7 3,098 08-12-2023, 01:59 AM
Last Post: User 27258
  PineBook Pro dead ottahe 9 6,148 01-18-2023, 07:41 PM
Last Post: ottahe
