Would you like to see and buy the 2.2 revision?
Yes, please!
91.67%
55
No, thank you
8.33%
5
60 vote(s)
PineBook Pro revision 2.2: Wishlist for the hardware issue fixes
#85
(09-11-2021, 03:46 PM)KC9UDX Wrote: If it were me, I'd remove the USB-C port altogether. I don't use this one lest I have to, because I worry about it. I've had possibly just one barrel jack fail from extreme abuse in five decades. The only way to convince me to get rid of it would be to replace it with that new Apple connector or something like it. It is mechanically superior to small USB connectors, vastly so.
The problem with barrel jacks are that they are not standard, if your charger breaks or gets lost, it is very hard to replace it. Meanwhile a generic USB charger with a Type-C cable for a tablet can be bought from even road side gas stations or just use the same charger that you already have for your phone / tablet.
I'm not sure which "new Apple plug" do you mean? Apple has been increasingly using USB Type-C on their products, even on tablets.
RE: PineBook Pro revision 2.2: Wishlist for the hardware issue fixes - by slyecho - 09-15-2021, 07:58 AM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 682 05-06-2024, 09:27 AM
  New Hardware names_mark_ 1 256 04-23-2024, 08:41 AM
Last Post: dachalife
  Pinebook Pro on Debian 12 Power Issue u974615 1 372 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 316 02-17-2024, 07:06 PM
  Pine Dock Networking Issue trillobite 1 300 02-10-2024, 12:03 AM
Last Post: trillobite
  Pinebook Pro charging issues tomekdev 1 658 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,161 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,367 09-13-2023, 03:43 AM
Last Post: k3dAR
  Hardware makes a strange pop noise. Gemeindepirat 7 3,070 08-12-2023, 01:59 AM
Last Post: User 27258
  PineBook Pro dead ottahe 9 6,104 01-18-2023, 07:41 PM
Last Post: ottahe
