[Updated] Let's see which applications are compatible with the PinePhone on Manjaro
(12-08-2020, 02:07 PM)dthaha Wrote: Bitwarden: 0
Doesn't start. I believe it has to do with HW acceleration, but don't quote me on that one. I just use the Firefox add-on for now.
I haven't used Bitwarden (and still haven't tried Manjaro on the PinePhone), but I read it uses Electron. Maybe try running it via the terminal and adding "--disable-gpu" (no quotes) to the end? This works for GB Studio 2, which is also Electron-based. If that works, you can modify the "Exec=" line in the .desktop file in /usr/share/applications/ to run the command with "--disable-gpu" until HW acceleration is implemented.
RE: [Updated] Let's see which applications are compatible with the PinePhone on Manjaro - by patrickmollohan - 12-09-2020, 06:14 PM
  systemic issue pinephone penguins_rule 3 441 04-02-2024, 11:52 AM
  link for supported pinephone os manjharo et all penguins_rule 2 248 03-19-2024, 10:36 AM
Last Post: penguins_rule
  Manjaro: Settings doesnt open nbh 0 598 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,525 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 1,608 05-10-2023, 09:27 PM
  new PinePhone upgrade issue WhiteHexagon 5 1,811 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 815 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,813 03-02-2023, 07:25 PM
  Can't add micro SD card to Pinephone thorensjubilee 7 2,550 02-27-2023, 10:21 AM
Last Post: mikehenson
  Can't install Manjaro thorensjubilee 1 1,038 02-09-2023, 08:17 AM
