[Updated] Let's see which applications are compatible with the PinePhone on Manjaro
(12-06-2020, 10:56 PM)pacman99 Wrote: Theres a really cool website with this information already: https://linmobapps.frama.io/
That's a cool list, however..
From what I understand, the way of how many linux applications will run on your mobile device is most of the times: device, operating system and shell dependent-
and since most linux-arm distros have different versions of different libraries bundled into them, which will result in different results for many applications (e.g. what might run perfectly on a Liberm5 will not run as good on a PinePhone, and vice verse..).
This is exactly my aim with this thread, it was posted under the "Manjaro on PinePhone" forum, which means that what is being discussed, is targeted / tested specifically for PinePhones that are running Manjaro-arm.
Thanks anyway for your contribution Smile
RE: [Updated] Let's see which applications are compatible with the PinePhone on Manjaro - by kern707 - 12-08-2020, 08:21 AM
  link for supported pinephone os manjharo et all penguins_rule 3 340 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 497 04-02-2024, 11:52 AM
  Manjaro: Settings doesnt open nbh 0 620 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,715 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 1,684 05-10-2023, 09:27 PM
  new PinePhone upgrade issue WhiteHexagon 5 1,895 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 845 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,987 03-02-2023, 07:25 PM
  Can't add micro SD card to Pinephone thorensjubilee 7 2,669 02-27-2023, 10:21 AM
Last Post: mikehenson
  Can't install Manjaro thorensjubilee 1 1,067 02-09-2023, 08:17 AM
