[Updated] Let's see which applications are compatible with the PinePhone on Manjaro
(11-30-2020, 08:22 AM)kern707 Wrote: LibreOffice (Writer, Calc, Draw, Impress)
Description: A complete and free office suit for linux.
Pinephone Compatibility rating: 1 (Partially compatible)
Notes:
1. I have tested the most used applications which are Writer (word processor), Calc (Spreadsheet software), Draw (Draw / PDF editing) and Impress (Presentation software)
2. Most functions work on a scale of from "ok-ish" to "pretty well" on the PinePhone.
3. Most of the UI elements were not optimized for a mobile device, but they seem to be useful even in the way they are.
3. The biggest major issue that I have found is that most dialog windows are not compatible with mobile device screens, they just open too large and are not usable, for some of them you could switch to Portrait mode and get around, but this is not intuitive.
Have you tried with the scale-to-fit command for the issue with the dialog windows? These instructions are for Mobian but I believe they are applicable to Manjaro as well, it's still phosh after all. I would try myself, but unfortunately I don't have much time Sad
Pinephone Braveheart
Pinephone Manjaro CE 3/32Gb
Pinephone Mobian CE 3/32Gb
Pinephone Pro Explorer Edition
RE: [Updated] Let's see which applications are compatible with the PinePhone on Manjaro - by deedend - 12-06-2020, 08:55 PM
  link for supported pinephone os manjharo et all penguins_rule 3 341 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 500 04-02-2024, 11:52 AM
  Manjaro: Settings doesnt open nbh 0 620 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,723 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 1,684 05-10-2023, 09:27 PM
  new PinePhone upgrade issue WhiteHexagon 5 1,898 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 845 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,987 03-02-2023, 07:25 PM
  Can't add micro SD card to Pinephone thorensjubilee 7 2,670 02-27-2023, 10:21 AM
Last Post: mikehenson
  Can't install Manjaro thorensjubilee 1 1,067 02-09-2023, 08:17 AM
