Pinebook pro crashing when put to sleep?? [Manjaro]
downgrade is a package, install like any other package,, then
sudo downgrade linux,,, it gives a menu, choose version, answer if you want it "pinned"
It may be in arch, not sure, so that repo should be enabled if downgrade not found
If you are using kde,, systemsettings5 for ->power management ->button handling checked,,
ignore lid close, pwr button ask
RE: Pinebook pro crashing when put to sleep?? [Manjaro] - by wdt - 10-29-2020, 12:05 PM
  Debian on Pinebook Pro u974615 7 1,062 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 291 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,621 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,765 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 337 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,163 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,237 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,131 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 415 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,257 11-23-2023, 07:37 AM
