Initial thoughts, PinePhone PostMarket edition.
#21
(09-08-2020, 07:00 PM)bcnaz Wrote: I did a manual update from the 'onboard software store', and it has usable audio again now.
>> One difference I have noticed when reading the many posts, every one of them mentions turning on the SSH & encryption...
    I skipped that when I first started my phone and,  it "Just Worked"....
I figured for "Testing" the phone,  encryption was not necessary, but now I wonder if that is what 'broke'  many of the phones.?
Just Wondering....
Very interesting, you say the audio is working after a manual update?  I'll have to try that!
BTW, I didn't enable SSH or disk encryption and I had the issue off the bat.  I'll try updating the phone.
Just Wondering....
We have two threads going on in slightly different tangents, but I'll post both for the benefit of anyone coming along after to find the information.
I tried the updates but recieving call audio still didn't work after.  I then had the bright idea to use the jumper block to disconnect the earphone from the audio circuit and test it.
That did make the call audio work. It is hardware bug as far as I can tell!
If I have switch 6 in the ON position (headphone enabled) the call audio is broken completely (distorted, inaubiable etc)
If I have switch 6 in the OFF position (uart enabled, headphone disabled), the call audio works properly!
Is there any chance you changed the switch position 6 on the jumper block to off and then just thought the updates fixed it after?  Your issue sounds the same as mine would be interesting if the same thing can happen with different causes, or perhaps we can pinpoint the exact cause!
RE: Initial thoughts, PinePhone PostMarket edition. - by Xerxes 8933A/A - 09-08-2020, 08:46 PM
  Software app in postmarket gnome shell Uturn 1 663 09-06-2023, 05:27 AM
Last Post: alaraajavamma
  [Not Pinephone] Phosh Autologin LienRag 11 2,221 09-01-2023, 10:55 PM
Last Post: rocket2nfinity
  Issues after installing latest PostMarket OS with POSH xen314 4 1,474 08-20-2023, 11:18 PM
Last Post: xen314
  Pinephone 64 PostMarketOS edition Battery Issues, Not Hardware Issue X0X0X0X0X0 1 1,434 02-11-2023, 08:19 AM
Last Post: acid andy
  Postmarket os printer setup Chief 3 2,283 01-21-2023, 04:27 PM
Last Post: jojuma
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 1,438 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 1 1,196 11-06-2022, 06:41 PM
Last Post: Chief
  no screen rotation on pinephone pro with postmarketOS + phosh elode 2 2,727 07-03-2022, 09:13 AM
Last Post: a.h.littorin
  Pinephone Keyboard Utilities on postmarketOS elof 2 3,240 06-20-2022, 01:33 PM
Last Post: elof
  PinePhone, getting started totilele 1 1,507 06-15-2022, 01:56 AM
Last Post: wibble
