How do I get into Loader mode to flash an image?
I'm following the guide at https://github.com/ayufan-rock64/android-7.1 but failing at step 3
Step 1 is to d/l and compile rkflashtool (done)
Step 2 is to connect a USB A-to-A cable to the upper USB2 port on the Rock64 and my computer (I assume any old male-to-male / A-to-A cable will do)
Step 3 is to put the Rock64 into Loader mode but no matter what I do, it just goes through the normal boot process and ends up at a ' => ' prompt
The specific steps are
i) press and hold recovery button
ii) press reset button
iii) stop holding recovery button after 3 seconds
Is there any visual change I should be seeing on the console to let me know it's in Loader mode?
When I run 'rkflashtool n' to verify it tells me 'fatal: cannot open device.'  I'm also not seeing anything in 'dmesg' (but maybe that's normal)
My Rock64 is microSD only, no eMMC.
How do I get into Loader mode to flash an image? - by olivercfc - 08-15-2020, 07:33 AM
  how to flash recovery daliang1215 3 6,486 09-09-2020, 07:16 AM
Last Post: BowerR64
  Cannot flash android 9 rockchip tool totalgaara 2 4,744 09-09-2020, 07:05 AM
Last Post: BowerR64
  Utility to make Android SDCard image jonsmirl 2 5,007 09-09-2020, 06:59 AM
Last Post: BowerR64
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 3 6,318 06-17-2020, 10:01 AM
  Android TV 9 - sleeping mode and backup Ludovic 0 2,733 04-24-2020, 03:39 AM
Last Post: Ludovic
  [RESOLVED] Stuck in recovery mode Danielsan 1 2,715 04-23-2018, 09:12 AM
Last Post: Danielsan
  USB flash error elis 0 1,639 04-14-2018, 12:26 PM
Last Post: elis
  how to get root for Android 7.1.2 Stock Image [eMMC Boot] [Rooted] [20171204] el_gringo 1 3,294 03-02-2018, 04:50 AM
Last Post: el_gringo
  [2017-07-04] SADIE -- Simple way to flash Android to your Rock64! fire219 7 16,902 08-23-2017, 12:01 PM
Last Post: Jakr
