sagemath on Manjaro (or Debian)
#19
It's worth noting that you are not bound to a distribution's default desktop environment. I believe the Pinebook Pro images focus on providing a usable graphical environment - if you are unable to use a conventional installer, you can still remove unwanted packages.
Debian offers gnome-core and gnome-shell as leaner metapackages for GNOME, should you wish to remove the gnome metapackage from a tty. If packages aren't a dependency of the metapackage (evolution-data-server is a dependency in gnome-core and gnome-shell, whereas evolution is a dependency in gnome), you can remove them without risking breakage.
Moreover, you can use the tasksel interface to install different desktop environments. Though removing a DE via this interface doesn't seem to work in the same way as via apt.
sagemath on Manjaro (or Debian) - by pine76 - 08-07-2020, 05:11 AM
RE: sagemath on Manjaro (or Debian) - by pine76 - 08-07-2020, 06:34 AM
RE: sagemath on Manjaro (or Debian) - by pine76 - 08-07-2020, 06:48 AM
RE: sagemath on Manjaro (or Debian) - by pine76 - 08-07-2020, 10:36 PM
RE: sagemath on Manjaro (or Debian) - by pine76 - 08-08-2020, 02:26 PM
RE: sagemath on Manjaro (or Debian) - by pine76 - 08-08-2020, 07:15 PM
RE: sagemath on Manjaro (or Debian) - by wdt - 08-08-2020, 07:37 PM
RE: sagemath on Manjaro (or Debian) - by pine76 - 08-08-2020, 07:45 PM
RE: sagemath on Manjaro (or Debian) - by wdt - 08-08-2020, 10:35 PM
RE: sagemath on Manjaro (or Debian) - by pine76 - 08-09-2020, 05:40 AM
RE: sagemath on Manjaro (or Debian) - by wdt - 08-09-2020, 08:22 AM
RE: sagemath on Manjaro (or Debian) - by pine76 - 08-09-2020, 02:04 PM
RE: sagemath on Manjaro (or Debian) - by pine76 - 08-11-2020, 08:42 AM
RE: sagemath on Manjaro (or Debian) - by User 18618 - 08-11-2020, 10:40 AM
  Debian on Pinebook Pro u974615 7 1,049 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 290 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,764 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 336 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,158 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,235 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 415 12-07-2023, 03:11 PM
  install debian on pbp jsch 7 4,058 11-22-2023, 04:22 PM
Last Post: TRS-80
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 906 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,448 09-07-2023, 09:38 PM
