sagemath on Manjaro (or Debian)
(08-10-2020, 01:30 PM)jed Wrote: Does testing install an LTS kernel (4.19, 5.4) by default? If so, you may want to install 5.7 or newer, which has improved support for exfat. You still require the userspace tools for exfat - as far as I know, this is exfat-progs.
Regardless, it seems you are finding success on Fedora. While this is not a solution, you can bypass the SD card issue by installing your OS to eMMC.
Ah, I switched back to Debian Bullseye again. Fedora felt too heavy but currently Debian Bullseye Gnome is chewing up my processor and battery with 'evolution-calendar'. I had a slight problem in connecting to bluetooth in Debian i don't have it. Debian has other issues...
On Bullseye, uname -r  command gives me
5.5.0-1-pinebookpro-arm64
Afaik Debian stable is on 4.19 kernel. I have eliminated to restore my files from the 2TB hard disk by removing the sd from pbp, plugging sd with adapter into my laptop and doing all the backup restoration process there. It was very easy and i can't believe I spent more than a week in restoring my files directly on pbp.
sagemath on Manjaro (or Debian) - by pine76 - 08-07-2020, 05:11 AM
RE: sagemath on Manjaro (or Debian) - by pine76 - 08-07-2020, 06:34 AM
RE: sagemath on Manjaro (or Debian) - by pine76 - 08-07-2020, 06:48 AM
RE: sagemath on Manjaro (or Debian) - by pine76 - 08-07-2020, 10:36 PM
RE: sagemath on Manjaro (or Debian) - by pine76 - 08-08-2020, 02:26 PM
RE: sagemath on Manjaro (or Debian) - by pine76 - 08-08-2020, 07:15 PM
RE: sagemath on Manjaro (or Debian) - by wdt - 08-08-2020, 07:37 PM
RE: sagemath on Manjaro (or Debian) - by pine76 - 08-08-2020, 07:45 PM
RE: sagemath on Manjaro (or Debian) - by wdt - 08-08-2020, 10:35 PM
RE: sagemath on Manjaro (or Debian) - by pine76 - 08-09-2020, 05:40 AM
RE: sagemath on Manjaro (or Debian) - by wdt - 08-09-2020, 08:22 AM
RE: sagemath on Manjaro (or Debian) - by pine76 - 08-09-2020, 02:04 PM
RE: sagemath on Manjaro (or Debian) - by pine76 - 08-11-2020, 08:42 AM
  Debian on Pinebook Pro u974615 7 1,385 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 337 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,810 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 387 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,252 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,353 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 465 12-07-2023, 03:11 PM
  install debian on pbp jsch 7 4,185 11-22-2023, 04:22 PM
Last Post: TRS-80
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 971 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,676 09-07-2023, 09:38 PM
