how do I know which linux OS I can install on a pinetab
"PC" hardware is very standardised. The vast majority of one "PC" is very, very compatible with every other "PC". The exception is individual expansion hardwares, which need new drivers (firmware) when they are introduced. What helps is that most hardware developers write drivers for Windows. Many even publish how to write drivers. A good example of an exception is Nvidia. Windows is the only operating system that Nvidia wants to work with their hardware.
In general, hardware that Pine64 uses, is not Windows-compatible. So we rely on manufacturer's specs, or reverse engineering, to make it work. That's why it takes time to get these things working.
I'm not savvy to the particulars of the PineTab itself. It may be quite similar to the Pinebook (not Pinebook Pro). But it may not. If operating systems that run on the Pinebook all run unmodified on the PineTab, then they are similar. But probably not. PineTab might have more in common with PinePhone, which also I don't know too much about. Hopefully someone with more specific knowledge of these products can comment.
RE: how do I know which linux OS I can install on a pinetab - by KC9UDX - 09-08-2020, 07:00 PM
  Pinetab 2 just arrived + when can hope to se wifi driver LRP 15 8,252 02-28-2024, 05:03 AM
Last Post: Surehand53
Wink Screen protector for PineTab 2 vatin 0 596 11-18-2023, 01:31 AM
Last Post: vatin
  What's the MAX RAM you can install to PineTab2? Ptab2newb 2 1,052 09-12-2023, 12:38 PM
Last Post: Ptab2newb
  PineTab 2 (arm64) thoughts and questions acruhl 7 3,093 09-01-2023, 01:13 PM
Last Post: acruhl
  PineTab 2 Dead Screen Kramey 16 5,088 08-12-2023, 05:44 PM
Last Post: Kramey
  pinetab 2 not booting ajhiii070 5 1,961 08-07-2023, 01:46 PM
Last Post: r.aliaskarov
  does the pinetab "just worK"? averageconsumer445 19 4,945 07-15-2023, 10:31 AM
Last Post: dachalife
  Pinetab-V shipping Status? jfstepha 6 2,551 07-12-2023, 03:23 PM
Last Post: ChromaticHamster
  No WiFi or Ethernet on vanilla PineTab 2 from the factory? SmittyWerbenyegermanjenson 6 2,435 06-06-2023, 05:26 PM
Last Post: fxc
Star Looking for a Pinetab [EU] Glenn 2 2,710 01-24-2023, 06:12 PM
Last Post: Louis
