Latest Installer Image hangs after updates
(07-19-2020, 08:39 PM)u20200719 Wrote: I used the latest 2020-Jul-16 12:26 image and was able to burn and SD card then go through the installation.  Once the installation completed and rebooted I went to the Software application and chose updates.  I got an initial error message about a Gnome component which I closed out then it showed all the updates.  I applied all the updates and rebooted.  Now it just hangs with a white/green/purple LED cycling.  I have tried this twice on two different SD cards with the same result.
Is this expected or have others noticed the same behavior?
Here's a video showing the install, update, and boot failure after the update.
http://www.filedropper.com/postmarketosinstaller
Downloading and copying image to SD
wget https://images.postmarketos.org/pinephon...ler.img.xz
xz -d pine64-pinephone-20200716-phosh-v20.05-installer.img.xz
md5sum pine64-pinephone-20200716-phosh-v20.05-installer.img
0a09f1c62457076241eb5c9dd6dae631  pine64-pinephone-20200716-phosh-v20.05-installer.img
sudo dd if=pine64-pinephone-20200716-phosh-v20.05-installer.img of=/dev/sdb bs=4M
895+1 records in
895+1 records out
3757047808 bytes (3.8 GB, 3.5 GiB) copied, 411.442 s, 9.1 MB/s
RE: Latest Installer Image hangs after updates - by u20200719 - 07-20-2020, 11:21 AM
  Firefox Crashes on Start-up (latest installer) & How do I change Default Browser? aLoop100o 1 485 11-22-2023, 10:16 AM
Last Post: zetabeta
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 859 10-03-2023, 06:32 PM
  Issues after installing latest PostMarket OS with POSH xen314 4 1,474 08-20-2023, 11:18 PM
Last Post: xen314
  how to install updates? someGermanGuy 2 2,005 04-26-2022, 12:48 PM
Last Post: someGermanGuy
  Latest suggestion to fix modem instability? feklee 10 8,827 01-31-2022, 01:16 PM
Last Post: feklee
  Latest build no firefox, text editor? cosmicschock 2 2,358 10-03-2021, 12:19 PM
Last Post: cosmicschock
  Where is the original PM OS image for Pinephone? mw4jet 1 2,644 03-14-2021, 07:37 AM
Last Post: ludix
  PMOS test image: failed EG25 test broke modem fw MtnSk8 4 5,773 02-28-2021, 02:20 PM
Last Post: MtnSk8
  Is a Software update the same as instaling an updated image Word5 1 2,956 09-19-2020, 10:23 PM
Last Post: jmorris
  Incorrect Passphrase - FIx | How To Reinstall Image. NobodyNew1 0 2,146 09-02-2020, 09:30 PM
Last Post: NobodyNew1
