Pinebook Pro Battery Mod Tips and Images
I decided to increase the battery capacity of my PBP by adding an additional 2600mAh LiPo battery in parallel to the stock battery - images attached.
Sharing some tips for anyone else who may want to attempt the mod.
  • Due to the narrowing of the PBP towards the trackpad, ensure that the battery you want to add will fit with the lower panel screwed on.
  • The stock battery is comprised of two LiPo cells in parallel, a plastic frame with four screw holes, a dense foam filler (as there is some empty space between the LiPos and the plastic frame), taped together with large black adhesive sheets.
  • The tape/adhesive sheet used to assemble the battery isn't TOO difficult to work with but the adhesive on the larger sheets may come off as you peel it back.
  • There is a battery protection circuit that electronically resides between the LiPo cells and the battery connector that connects to the main board.
  • The battery protection circuit has six pads - three for battery negative, and three for battery positive.
  • The additional battery can be connected to available or occupied pads on the battery protection circuit as needed - you should only do so when the voltages of the batteries are nearly identical.
  • For my mod, I removed a portion of the plastic frame and foam to make room for the additional cell so that the battery would be more compact overall.
.jpg   IMG_6570 - Copy.JPG (Size: 231.75 KB / Downloads: 1,108)
.jpg   IMG_6571 - Copy (Large).JPG (Size: 284.64 KB / Downloads: 1,042)
.jpg   IMG_6572 - Copy - Copy (Large).JPG (Size: 363.88 KB / Downloads: 1,068)
Pinebook Pro Battery Mod Tips and Images - by phuzy - 07-10-2020, 12:38 PM
  pinebook pro dixplays vertical stripes WEF 2 1,111 03-23-2025, 03:31 PM
Last Post: WEF
  Bad replacement battery? chris88233 4 2,542 11-14-2024, 06:05 PM
Last Post: reukiodo
  Yet another new Pinebook keyboard problem MikoBob 3 1,439 09-11-2024, 07:05 AM
Last Post: MikoBob
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 4,114 05-06-2024, 09:27 AM
  Lithium Battery Connector Franestra 0 881 04-02-2024, 01:52 AM
Last Post: Franestra
  Pinebook Pro on Debian 12 Power Issue u974615 1 1,462 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 1,456 02-17-2024, 07:06 PM
  Bypassing the Battery gilwood 0 929 02-01-2024, 10:45 AM
Last Post: gilwood
  Pinebook Pro charging issues tomekdev 1 1,713 01-05-2024, 08:40 PM
Last Post: tomekdev
  PBPro Battery specification Perl6_user 3 2,343 12-26-2023, 04:28 PM
Last Post: DrYak
