Not booting , Black screen backlight is on
(07-01-2020, 12:43 PM)rocket2nfinity Wrote:
(07-01-2020, 10:19 AM)bigtallviking Wrote:
(07-01-2020, 05:00 AM)rocket2nfinity Wrote:
(07-01-2020, 03:32 AM)maba Wrote: Same here. Pinephone UBports Edition.
I had problems with booting from the SD from start "of out of the" box.
I succeeded once with Postmarket OS. Made no changes to EMMC. Only booting from SD.
After I tried to SD boot  with UBPorts an older version II can't boot at all.
No Jumpdrive , no factory image works from the SD.
Tried different SD cards. Power should be ok.
After the Pine Logo the screen is dark no read activity from the LED.
Woops....
Now what?
/Maba
Sounds like partition tables got corrupted. Run gparted on your SD cards and then re-install ubports on one, or the jump drive image. Insert, boot into recovery and see if it succesfully can.  If so, then run gparted on your emmc because it also is likely corrupted. Mine were. I reflashed after gparted and all works now. Running  ubports on emmc and pureOS on sdcard
Erased the SD card completely (SanDisk Ultra 32GB), ran gparted on it and then used dd to flash yesterday's release of jump drive. Popped into the phone with battery fully charged, the display is still not showing anything and only the backlight is turning on. Have a 6MB video of the boot process but not sure I can attach it here, can message or PM if needed (edit: added to the Telegram chat)
Can you try with UBPorts build 54 from this June? Do not do the clock patch, just dd the image file to the SD card and try to boot to recovery
Ahumm, if there was a forum thread named: "Hall of Lame" I will be high listed.
But here is my confession.
I haven't used a SIM-card yet because I only want to discover first. And my old eyes didn't noticed I have put the SD-card Angel in the SIM part.
My eMMC is corrupted that's for sure. But I have Mobian running from the SD.
Thanks for your help and sorry for your time....
/Maba
RE: Not booting , Black screen backlight is on - by maba - 07-01-2020, 01:24 PM
  Pinephone not booting, always vibrating alexander12 7 5,090 11-22-2023, 06:46 PM
Last Post: Scary Guy
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 5,349 08-28-2023, 11:38 AM
Last Post: fxc
  locked out on PIN screen g40 1 671 06-07-2023, 10:20 PM
Sad New PinePhone won't boot 9/10 times - Screen is on but stays black :( dante404 8 5,371 02-03-2023, 01:27 AM
Last Post: dante404
  My screen bottom side has loosed its tactile function arbocenc 1 838 01-06-2023, 10:02 AM
Last Post: britelite
  "PinenotePhone": Swap E-Ink Screen Onto Pinephone? britelite 0 686 01-03-2023, 06:17 PM
  Screen seems ok but no display UncleMeat 3 1,657 11-03-2022, 07:02 AM
Last Post: fxc
Question Black screen no matter the OS joseph303 2 1,539 07-19-2022, 01:07 AM
Last Post: joseph303
  Boot problem: wrong screen orientation Jetpac 6 3,846 07-18-2022, 12:47 PM
Last Post: fravoi
  Manjaro phosh no screen rotation sandspur 1 1,354 06-23-2022, 01:02 AM
Last Post: rapp
