Not booting , Black screen backlight is on
(06-24-2020, 03:27 PM)pokemanearth Wrote: I got my pinephone today. Switched on, it worked ,  did some setting changes, rebooted several time. After a few hours rebooted, then it stop booting up. The LCD backlight is on, the led flashes red green white in the beginning and nothing.  Screen goes to sleep, if I press power the backlight comes on but the screen is black.  Cannot go into recovery mode.  Flashed other OS in  SD same problem. Flashed fedora , lcd backlight does not even come up, after 30 sec led light next to camera  switches on .Strange issue , any idea? Thanks.
Experiencing the same issues as well, was able to boot out of the box and use the OS for about an hour, experienced some screen flickering after enabling the auto brightness feature and the screen went dark. Have not been able to get anything displayed on the screen since, but it does show that the backlight is coming on. I have attempted to boot from SD, boot from jumpdrive, flash a new UBPorts (current version and an older version), Postmarket OS, and PureOS...none will allow the screen to show anything other than the dark backlight. The front LEDs will light up, I am able to telnet to the device using the jumpdrive, the phone will vibrate on boot (Postmarket OS), and the battery has been fully charged. Any advice or ideas would be great...
RE: Not booting , Black screen backlight is on - by bigtallviking - 06-29-2020, 10:31 AM
  Pinephone not booting, always vibrating alexander12 7 5,073 11-22-2023, 06:46 PM
Last Post: Scary Guy
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 5,327 08-28-2023, 11:38 AM
Last Post: fxc
  locked out on PIN screen g40 1 666 06-07-2023, 10:20 PM
Sad New PinePhone won't boot 9/10 times - Screen is on but stays black :( dante404 8 5,362 02-03-2023, 01:27 AM
Last Post: dante404
  My screen bottom side has loosed its tactile function arbocenc 1 835 01-06-2023, 10:02 AM
Last Post: britelite
  "PinenotePhone": Swap E-Ink Screen Onto Pinephone? britelite 0 686 01-03-2023, 06:17 PM
  Screen seems ok but no display UncleMeat 3 1,641 11-03-2022, 07:02 AM
Last Post: fxc
Question Black screen no matter the OS joseph303 2 1,530 07-19-2022, 01:07 AM
Last Post: joseph303
  Boot problem: wrong screen orientation Jetpac 6 3,839 07-18-2022, 12:47 PM
Last Post: fravoi
  Manjaro phosh no screen rotation sandspur 1 1,353 06-23-2022, 01:02 AM
Last Post: rapp
