Need to install 64-bit Ubuntu
(06-18-2020, 06:06 PM)Jeremiah Cornelius Wrote: Jump to danielt's unofficial Debian Installer thread with an installer for correctly debootstrap of 64-bit. His installer - on git - works for 64/32, Buster/Bullseye/Sid - depending on tweaks to the script files, and even allows for encrypted LUKS rootfs.
https://forum.pine64.org/showthread.php?tid=8487
Also, xmixahlx has a number of post-install enhancements/updates/etc for the danielT unofficial Debian Installer on his scripts page: pinebook pro tools. He's done work to make almost trivial, the compilation of latest kernels and MESA/GL updates, various HW acceleration, etc.
https://forum.pine64.org/showthread.php?tid=10190
Thanks, that helps.
Though, for what it's worth, I was able to install Swift 5 for AARCH under Manjaro (was designed for Ubuntu 18.xx). Had to locate some static libraries (copied them over from my RockPro64 machines), but Swift has managed to compile "Hello, World!" so I'm happy for the time being.
I'm working on a book ("An Introduction to Programming Using Swift") and I was making sure all the samples compiled on macOS, Windows, Linux (x86), Raspberry Pi, and RockPro64. Just wanted to add the PineBook Pro to the list (might actually go back and see if I can get Swift running on my old PineBook at this point--I'd given up on that a while back).
Cheers,
Randy Hyde
Need to install 64-bit Ubuntu - by rhyde - 06-18-2020, 02:59 PM
RE: Need to install 64-bit Ubuntu - by rhyde - 06-18-2020, 06:15 PM
RE: Need to install 64-bit Ubuntu - by Syonyk - 06-20-2020, 05:05 PM
RE: Need to install 64-bit Ubuntu - by rhyde - 06-20-2020, 06:00 PM
RE: Need to install 64-bit Ubuntu - by Syonyk - 06-20-2020, 06:25 PM
RE: Need to install 64-bit Ubuntu - by rhyde - 06-20-2020, 07:44 PM
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,930 08-03-2023, 03:30 PM
  Followed the blog post to install Fedora: PBP not booting anymore koenigs 6 1,918 06-01-2023, 10:58 AM
  Use SD to install new OS over pinebook debian Rudy558 9 10,848 09-25-2022, 01:19 AM
Last Post: jackwilson
  MiniConda Install Issues nixyhustle 0 809 09-16-2022, 10:06 PM
Last Post: nixyhustle
  Does anyone know how to install levinsboot on pbp? computerc 0 643 09-05-2022, 03:52 PM
Last Post: computerc
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,437 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  microsoft teams install problem jip 3 3,918 02-17-2021, 09:27 AM
Last Post: pagesix1536
  Install postgres motezart 5 8,605 10-28-2020, 03:18 PM
  help on setting up debian (or ubuntu) on micro sd card pine76 2 8,801 09-17-2020, 05:10 PM
Last Post: bcnaz
  Graphics issue on ubuntu bionic das 0 1,700 08-03-2020, 09:39 AM
Last Post: das
