Power consumption and suspend to ram
#25
(07-13-2020, 11:08 PM)xmixahlx Wrote: i am basically doing that in pbp-tools and my pinebook-pro-debian-installer fork with the hwaccel kernel on debian.
xmixahlx, thanks for the suggestions. Again I am new to this so I hadn't run across your stuff before.
When starting from scratch, a bit confused on whether to use the original debian-installer (which was updated as recently as 18 days ago) or yours. Is yours doing additional things to target deep sleep by default? Or maybe you simply use that different kernel than the original debian-installer? Are you looking to keep in sync by keeping on top of commits to the original script? Or?
Any interest in then posting the resulting image or do you prefer to keep it at the script level so that it won't need rebuilding all the time? Just curious over your longer term idea.
Regarding all the great tools in pbp-tools, are there several that are "good for all pbp users", then the others are if you want to install specific software packages, etc?
We would need to walk relatively low-tech users through the process of getting their pbp to a reasonable running state. That is why I am asking for any wiki updates and/or updated images.
Lastly, we have some software that is built for Ubuntu and distributed via ppa. Not sure what it may break but I would be testing if it would be reasonable to add and use an Ubuntu PPA.
Thanks again for the great work!
Power consumption and suspend to ram - by robt - 06-14-2020, 03:01 PM
RE: Power consumption and suspend to ram - by wdt - 06-15-2020, 10:42 AM
RE: Power consumption and suspend to ram - by wdt - 06-19-2020, 05:22 PM
RE: Power consumption and suspend to ram - by rik-shaw - 07-18-2020, 11:52 AM
RE: Power consumption and suspend to ram - by wdt - 08-03-2020, 08:00 AM
RE: Power consumption and suspend to ram - by wdt - 11-30-2020, 12:47 PM
RE: Power consumption and suspend to ram - by wdt - 11-30-2020, 04:32 PM
  Lockable-until-power-cycle persistent storage Melab 0 742 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 858 07-20-2023, 11:06 PM
Last Post: papable
  When does Pinebook Pro power LED go on? Bram 0 644 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 1,281 02-25-2023, 09:00 PM
Last Post: badguru
Heart Now better battery life or power management? KC9UDX 5 2,346 09-09-2022, 08:13 PM
  high battery drain on suspend/poweroff wiz 5 5,145 02-10-2022, 11:52 AM
  Replacement Power Cord recommendation? nathanielwheeler 3 3,351 01-23-2021, 06:43 PM
  power light blinking during charge when pbpro is off Idaho 0 1,826 01-04-2021, 10:53 AM
Last Post: Idaho
  Taming the power switch? ab1jx 4 4,938 11-30-2020, 10:57 PM
Last Post: rimaille
Exclamation Seemingly lost power permanently now /cry jimsurvak 2 3,114 11-16-2020, 06:22 PM
Last Post: jimsurvak
