Pinebook Pro not Booting at All eMMC or MicroSD
Perhaps it is more understandable with "more rational" numbers
idbloader is < 4M bs=512 seek=64 (ie,, 64 sectors from start of SD card)
uboot is often 4M size (or less),,bs=1M seek=8 (ie, from 8M->12M)
ATF/trust is often 4M (or less),,bs=1m seek=12 (ie,,from 12->16M)
user partitions start at 16M,, 32768 sectors, check with fdisk to see
The locations of idbloader, uboot, ATF(arm trusted firmware)
are "baked into" the bootrom
ATF does not seem to change very much, idbloader is very low-level initialization
uboot is either some version of rockchips BSP or mainline, both a bit immature
--edit--
Rarely, uboot and ATF are catted together,, uboot padded so ATF is in right place
This will be an image ~6.5M or more (up to 8M, last 1.5M zeros)
If this is happening, at 4M will be signature, "magic" for ATF,,, "BL3X" but hex of course
Not at all common
RE: Pinebook Pro not Booting at All eMMC or MicroSD - by wdt - 06-14-2020, 09:43 AM
  Debian on Pinebook Pro u974615 7 1,425 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,888 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,275 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,374 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 90,332 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 466 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,412 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,582 08-31-2023, 04:20 PM
Last Post: TRS-80
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,044 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 1,018 08-18-2023, 01:58 AM
Last Post: juliamenendez
