Pinebook Pro not Booting at All eMMC or MicroSD
(06-09-2020, 02:46 PM)AstroCEO Wrote: Hello,
I removed the eMMC attempting to do the u-boot installation.  However, it looks like nothing happened when I tried to do it because it didn't engage the microSD card at boot I guess.  However, I put the eMMC back on and it won't boot the regular Debian OS now at all?
Also, I can't get microSD to work as an alternative, although I have never once successfully used the microSD boot at this point.
Why won't it load?  Why does the power button blink green once, and then hold a orangish red color indefinitely?
Thanks, AstroCEO.
Can you give more details concerning how you were trying to install u-boot? Do you mean write it to the SPI? Or were you trying to write to your eMMC using the USB adapter?
Every PBP OS img so far has included a version of u-boot with it (otherwise they won't boot.) If your eMMC u-boot is faulty and enabled, you won't be able to boot to SD until you disable or remove the eMMC. After doing that, if your SD doesn't boot, you should look at the SD itsself, or verify you're writing the img to the SD correctly.
RE: Pinebook Pro not Booting at All eMMC or MicroSD - by tophneal - 06-10-2020, 07:37 AM
  Debian on Pinebook Pro u974615 7 1,425 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,888 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,274 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,374 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 90,331 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 466 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,412 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,582 08-31-2023, 04:20 PM
Last Post: TRS-80
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,044 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 1,018 08-18-2023, 01:58 AM
Last Post: juliamenendez
