Audio jack and external mic?
(06-08-2020, 12:18 PM)johns Wrote: Will the headset jack on the PBP work with combined mic/headsets? The wiki seems to say it should, but so far it doesn't for me. Using Manjaro, have tried two different headsets which work on other machines. Headset function works, but mic does not. The mic privacy switch is set to enabled, and the built-in mics are working (with the reported whine, of course). USB mic also works.
-john
You likely need to change the input port within your system sound settings.
The privacy switches only disable the internal mics, IIRC, and should not effect any external mics.
Audio jack and external mic? - by johns - 06-08-2020, 12:18 PM
RE: Audio jack and external mic? - by tophneal - 06-08-2020, 01:53 PM
RE: Audio jack and external mic? - by johns - 06-08-2020, 02:16 PM
RE: Audio jack and external mic? - by tophneal - 06-08-2020, 02:59 PM
RE: Audio jack and external mic? - by johns - 06-10-2020, 10:54 AM
RE: Audio jack and external mic? - by tophneal - 06-10-2020, 12:42 PM
  Got a PBP - batch(August/September) and the audio is not good(2 big issues) crazyquark 2 1,503 10-01-2022, 10:16 AM
Last Post: crazyquark
  No audio from HDMI with usb-c adapter rfm83 5 3,140 06-19-2022, 09:06 PM
Last Post: rfm83
  Issues with External Display After Recent Update reundo 0 1,381 11-18-2021, 06:37 PM
Last Post: reundo
  External Monitor resolution (would like 3840x2160) Phillip Bell 3 2,221 11-17-2021, 10:02 AM
Last Post: Phillip Bell
  Workaround for crackling audio when music starts/stops pato3 1 2,558 07-28-2021, 12:26 PM
Last Post: dsimic
  alsamixer and audio scale settings- how to make persistent straightwalker 0 1,487 06-04-2021, 10:57 AM
Last Post: straightwalker
  External DVD/CD MIchael 22 22,194 03-07-2021, 03:49 PM
Last Post: ab1jx
  External Monitor Recommendations SteveSquatch 1 1,815 02-17-2021, 08:23 AM
Last Post: Arwen
  Audio with Debian GloriousCoffee 5 7,357 10-15-2020, 01:22 PM
Last Post: Mangled
  [split] Change password from external media James Good 11 12,900 07-23-2020, 02:42 PM
