Pinebook Pro stuck in suspend
My PBP seems to be stuck in suspend mode. The power indicator LED is constantly red when the system is powered on, and the screen does not turn on. The power LED is normal (red) when plugged in, and the battery seems to be holding a charge. I've tried the reset button on the main board. I'm not sure what else to try. Any suggestions? Thanks in advance!
Press and HOLD power button ~20 seconds (+) for a complete power off ???
^before doing that connect power
(05-02-2020, 06:39 PM)xmixahlx Wrote: ^before doing that connect power
Hi, sorry for the delay in replying. I tried as you suggested holding the power button down for 20+ seconds several times with and without the power attached. The display is still not powering on. Any other suggestions? Thanks
Remove emmc, mrfixit's on SD (because of uboot, just a hunch)
Serial cable
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 617 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 357 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 301 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 643 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,139 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,121 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,082 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,497 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 137,475 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,930 10-21-2022, 07:57 AM
Last Post: dachalife
