New Pinebook Pro won't detect SD cards
Shocked
I recieved my Pinebook Pro this week and have been looking at getting a new OS on it today. I have a Sandisk SD card that I have formatted as FAT32 on my Mac. Upon insertion into the Pinebook Pro the SD card is not detected.
If I follow the `dmesg` logs there are no obvious messages when inserting the card which leads me to believe it is not being detected at all.
Is it possible I have recieved a unit with a faulty SD slot? What are the best ways to debug this issue?
Many thanks
One starting place would be to check the right USB port. Does any device in that right USB port work?
If nothing works in that right USB port, then perhaps it's a loose or poorly connected small board cable. The right ports are connected to the mainboard by a cable. So the flat cable could have a loose connection on either end.
Here is a picture of the small board, with the cable shown at the top of the picture.
[Image: Pinebook_pro_smallboard.jpg]
Arwen Evenstar
Princess of Rivendale
Thanks for your reply. After some more tinkering I got the SD card to show after a re-boot which is good progress. I also managed to boot from it.
If I insert an SD card whilst the operating system is running, the SD card is not detected. If I re-boot with the card in, it is detected. Are the cards not hot swappable?
it sounds like the emmc os isnt loading the proper module. do you get any errors in dmesg or syslog?
that isnt normal.
(03-23-2020, 02:14 AM)scottsweb Wrote: If I insert an SD card whilst the operating system is running, the SD card is not detected. If I re-boot with the card in, it is detected. Are the cards not hot swappable?
They should be.  Is the card formatted with a file system the OS can recognize?
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 615 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 356 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 300 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 640 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,138 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,094 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,078 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,496 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 137,421 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,930 10-21-2022, 07:57 AM
Last Post: dachalife
