New release time, version 20200322 is available Smile
This one comes with a bunch of small but useful improvements:
- upgrade phosh to latest version
- ambient light and proximity sensor now works and is used by phosh to set the display's brightness and disable touch/display when relevant
- hacked geary's account dialog in order to make it usable on the PP
- headset microphone is now supported
- added a "headset" button to Calls in order to switch between headset and earpiece+internal mic
There is a small issue with the Speaker/Headset buttons in Calls: the state of the audio routing is normally the same used for the previous call, but this isn't reflected in the UI
For example, if you make a call using the headset, the next one will use the headset too, but the "Headset" button will show as if it was disabled. In order to revert to internal earpiece+mic, you'll have to press it twice (force headset routing then revert to internal routing).
Also, the Geary account dialog might take a few seconds to react when selecting the mail provider, please be patient and don't frenetically select your provider again and again Wink
(03-21-2020, 02:30 PM)buffer Wrote: Checking alsamixer again (press F6 - select 1- Pinephone sound card), I see that when I change mic profile from Default to Phone, or from Phone to Default, in phosh sound settings, both Mic1 and Mic2 are muted. However (press F6 again - select 0- Default) on the main menu the capture device remains unmuted. However, unmuting the mics does not help make sound get recorded.
Well, I think I understand your issue, and really, when saying "out of the box", I mean "out of the box": you shouldn't need to fiddle with alsamixer or other more or less hidden settings, all the necessary configuration is already built-in.
In order to check whether it's a hardware issue with your phone's mic, flash the latest image to an SD card and boot it, then plug a headset in, and make a call. Touch the "Headset" button, and try talking into the headset's mic; if it works this way, then your phone's internal mic is probably dead, sorry...
bcnaz Wrote:Wanted to add : I am pretty much just a GUI driver, so I would like to find ways to contribute , you guys are putting some excellent efforts into this project.
Contributing with no technical skills is a bit difficult for now as a lot still needs to happen under the hood, but you can help by keeping the wiki section up-to-date or improving it, answering to others on this forum, and so on...
Regarding donations: I never considered that aspect for this project, but for those really wanting to donate, I have an old Liberapay account I never really used so far...
Thank you all for your support, bug reports and kind words, every one of those is highly  appreciated Smile
(03-22-2020, 05:38 AM)buskmann Wrote: Did a "sudo apt upgrade" for more or less one hour ago, and it stopped at 84%. Last thing it put out was: e2scrub_all.service is a disabled or a static unit not running, not starting it.
Hmmm, I had a similar issue, could you share the full apt log so I can double-check with mine?
Dont know if this works, but i Attached the logfile to this post.. Its a bit to big to post here Undecided
Just in case, heres the last part:
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 69240 files and directories currently installed.)
Preparing to unpack .../00-libasan5_9.3.0-6_arm64.deb ...
Unpacking libasan5:arm64 (9.3.0-6) over (9.3.0-5) ...
Preparing to unpack .../01-g++-9_9.3.0-6_arm64.deb ...
Unpacking g++-9 (9.3.0-6) over (9.3.0-5) ...
Preparing to unpack .../02-gcc-9_9.3.0-6_arm64.deb ...
Unpacking gcc-9 (9.3.0-6) over (9.3.0-5) ...
Preparing to unpack .../03-libstdc++-9-dev_9.3.0-6_arm64.deb ...
Unpacking libstdc++-9-dev:arm64 (9.3.0-6) over (9.3.0-5) ...
Preparing to unpack .../04-libgcc-9-dev_9.3.0-6_arm64.deb ...
Unpacking libgcc-9-dev:arm64 (9.3.0-6) over (9.3.0-5) ...
Preparing to unpack .../05-cpp-9_9.3.0-6_arm64.deb ...
Unpacking cpp-9 (9.3.0-6) over (9.3.0-5) ...
Preparing to unpack .../06-gcc-9-base_9.3.0-6_arm64.deb ...
Unpacking gcc-9-base:arm64 (9.3.0-6) over (9.3.0-5) ...
Preparing to unpack .../07-libibus-1.0-5_1.5.22-2_arm64.deb ...
Unpacking libibus-1.0-5:arm64 (1.5.22-2) over (1.5.22-1) ...
Preparing to unpack .../08-gir1.2-ibus-1.0_1.5.22-2_arm64.deb ...
Unpacking gir1.2-ibus-1.0:arm64 (1.5.22-2) over (1.5.22-1) ...
Preparing to unpack .../09-gnome-session-bin_3.36.0-2_arm64.deb ...
Unpacking gnome-session-bin (3.36.0-2) over (3.36.0-1) ...
Preparing to unpack .../10-gnome-session_3.36.0-2_all.deb ...
Unpacking gnome-session (3.36.0-2) over (3.36.0-1) ...
Preparing to unpack .../11-gnome-session-common_3.36.0-2_all.deb ...
Unpacking gnome-session-common (3.36.0-2) over (3.36.0-1) ...
Preparing to unpack .../12-libcom-err2_1.45.6-1_arm64.deb ...
Unpacking libcom-err2:arm64 (1.45.6-1) over (1.45.5-2) ...
Preparing to unpack .../13-libgtk3-perl_0.037-1_all.deb ...
Unpacking libgtk3-perl (0.037-1) over (0.036-2) ...
Preparing to unpack .../14-libss2_1.45.6-1_arm64.deb ...
Unpacking libss2:arm64 (1.45.6-1) over (1.45.5-2) ...
Preparing to unpack .../15-pci.ids_0.0~2020.03.20-1_all.deb ...
Unpacking pci.ids (0.0~2020.03.20-1) over (0.0~2020.02.22-1) ...
Preparing to unpack .../16-sudo_1.8.31p1-1_arm64.deb ...
Unpacking sudo (1.8.31p1-1) over (1.8.31-1) ...
Preparing to unpack .../17-pinephone-modem-scripts_0.4_arm64.deb ...
Unpacking pinephone-modem-scripts (0.4) over (0.3) ...
Preparing to unpack .../18-pinephone-base_0.2.4_arm64.deb ...
Unpacking pinephone-base (0.2.4) over (0.2.3) ...
Preparing to unpack .../19-pinephone-multimedia_0.2.4_arm64.deb ...
Unpacking pinephone-multimedia (0.2.4) over (0.2.3) ...
Preparing to unpack .../20-pinephone-tweaks_0.4_arm64.deb ...
Unpacking pinephone-tweaks (0.4) over (0.3) ...
Setting up pci.ids (0.0~2020.03.20-1) ...
Setting up pinephone-multimedia (0.2.4) ...
Setting up libibus-1.0-5:arm64 (1.5.22-2) ...
Setting up gnome-session-bin (3.36.0-2) ...
Setting up libcom-err2:arm64 (1.45.6-1) ...
Setting up libgomp1:arm64 (10-20200321-1) ...
Setting up pinephone-modem-scripts (0.4) ...
Setting up libatomic1:arm64 (10-20200321-1) ...
Setting up libss2:arm64 (1.45.6-1) ...
Setting up sudo (1.8.31p1-1) ...
Setting up logsave (1.45.6-1) ...
Setting up libubsan1:arm64 (10-20200321-1) ...
Setting up gnome-session-common (3.36.0-2) ...
Setting up gir1.2-ibus-1.0:arm64 (1.5.22-2) ...
Setting up libcc1-0:arm64 (10-20200321-1) ...
Setting up liblsan0:arm64 (10-20200321-1) ...
Setting up libgtk3-perl (0.037-1) ...
Setting up libitm1:arm64 (10-20200321-1) ...
Setting up libpython3-stdlib:arm64 (3.8.2-2) ...
Setting up gcc-9-base:arm64 (9.3.0-6) ...
Setting up libtsan0:arm64 (10-20200321-1) ...
Setting up pinephone-tweaks (0.4) ...
Creating boot script...
Image Name:   pinephone
Created:      Sun Mar 22 10:57:41 2020
Image Type:   AArch64 Linux Script (uncompressed)
Data Size:    811 Bytes = 0.79 KiB = 0.00 MiB
Load Address: 00000000
Entry Point:  00000000
Contents:
   Image 0: 803 Bytes = 0.78 KiB = 0.00 MiB
Setting up e2fsprogs (1.45.6-1) ...
Installing new version of config file /etc/mke2fs.conf ...
update-initramfs: deferring update (trigger activated)
.log   logapt.log (Size: 328.06 KB / Downloads: 178)
Hmmm, nothing really stands out as to why it crashed... Did you try "sudo dpkg --configure -a" after rebooting ?
Did it now.
Heres the output:
Setting up python3 (3.8.2-2) ...
running python rtupdate hooks for python3.8...
running python post-rtupdate hooks for python3.8...
Setting up libasan5:arm64 (9.3.0-6) ...
Setting up pinephone-base (0.2.4) ...
Setting up cpp-9 (9.3.0-6) ...
Setting up libgcc-9-dev:arm64 (9.3.0-6) ...
Setting up gcc-9 (9.3.0-6) ...
Setting up libstdc++-9-dev:arm64 (9.3.0-6) ...
Setting up g++-9 (9.3.0-6) ...
Processing triggers for desktop-file-utils (0.24-1) ...
Processing triggers for mime-support (3.64) ...
Processing triggers for initramfs-tools (0.136) ...
update-initramfs: Generating /boot/initrd.img-5.5-pinephone
Processing triggers for libglib2.0-0:arm64 (2.64.1-1) ...
Processing triggers for libc-bin (2.30-2) ...
Processing triggers for systemd (245.2-1+pinephone1) ...
Processing triggers for man-db (2.9.1-1) ...
Setting up gnome-session (3.36.0-2) ...
I have just built my first image now, so gonna flash it today..
I gave the new image a try today. It looks good. I love being able to run Debian on my phone.
I didn't try the phone functions, but was listening to music with mplayer in the terminal, tried out a little browsing with Midori and Lynx, etc. The battery life seems relatively good too.
The Contact book and the texting work ok, but when I click on 'start chat' there are double entries of every name in the contact book ?
The second one of each has the name but no phone number. The other has all the info entered.
Not a big deal, but thought I would mention it.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
I was trying to change the username, so i logged in via ssh as root, and did:
pkill -9 -u `id -u debian`
usermod -l buskmann debian
usermod -m -d /home/buskmann buskmann
Now the phone wont log in and start phosh.
I assume that some auto login file that has the username "debian" in it or something.
If so, what file should i edit to get my username in there?
And is it maybe possible to use "uid" instead of username?
(03-22-2020, 08:34 PM)buskmann Wrote: I was trying to change the username, so i logged in via ssh as root, and did:
Please have a look :
https://forum.pine64.org/showthread.php?...5#pid62245
Thank you for directing me. I havent read threw all the pages of this forum, but now i read everything.
So I installed gdm3, and setup auto login, and now it works. Smile But the weird thing is that before i setup auto login, i had to login with the user "debian" whitch does not exist..
But i think im going to reflash and keep the user to "debian".
Im writing my own little afterinstall script to make the changes i want on it, like pwfeedback is sudo, growpart and keyboard layout.
But the part with changing the user seems like its not worth it.
Im learning a lot from this now, and its really fun. I live in Spain, where we have nationwide quarantine, so i have to have something like this to occupy me, or else i would go crazy..
Ok,
This message for @a-wai
I think it works Smile
Send from my 5mn hotspot
//Edit a 10mn
But PP charging. Gonna unplug in one minute.
//Edit
Unplugging
//Edit
Ok
Still on battery..
//Edit
Just cut the hotspot
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 16 2,025 3 hours ago
Last Post: zetabeta
  unofficial kali linux for pinephone help needed pinesmell 5 3,634 01-08-2024, 02:50 PM
Last Post: ERPlegend
  Auto start application on Phosh login Zebulon Walton 8 3,374 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,379 08-31-2023, 12:38 PM
Last Post: vusra
  Has anyone got briar-desktop running on mobian? vusra 5 3,028 06-19-2023, 03:02 PM
Last Post: vusra
  Using sway along phosh fdlamotte 2 3,315 05-11-2023, 04:24 PM
Last Post: kabouik
  Axolotl on PinePhone / Mobian arno_nuehm 219 165,652 03-26-2023, 01:49 AM
Last Post: shulamy
  PinePhone won't boot after software update jb2000 2 1,337 03-17-2023, 07:26 AM
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,193 03-01-2023, 04:45 PM
Last Post: anonymous
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 1,791 02-24-2023, 12:11 AM
Last Post: nexion
Users browsing this thread: 16 Guest(s)
