New Pinebook releases (28.10.2018) - Ayufan
Star
New Pinebook releases from ayufan - including Bionic with LXDE, Xenial with Mate and Stretch minimal.
Do note that that OS images designated for Pinebooks with 1080p IPS panel are designated accordingly. N.B. The new images are also available for Pinebooks from previous batches with non-1080p ISP screens.
Download here
Thank you for this! Couple of Q's:
  • How comes the move to LXDE for 18.04?
  • There's a note in the changelog:
Quote:Only xenial do support GUI, the rest of builds do miss required system packages
Does that mean that upgrading to the latest xenial mate image, then running do-system-upgrade that the aufan image won't work on 18.04?
Much appreciated all the work that goes into this!
[ PHP Developer | Pinebook 1G | About me ]
So there will be a new version of 11,6" Pinebook with 1080p display with the same CPU? It will be a bit overkill, or not?
(10-31-2018, 03:01 AM)Wizzard Wrote: So there will be a new version of 11,6" Pinebook with 1080p display with the same CPU? It will be a bit overkill, or not?
Seems runs well :-)
I've tried the LXDE 0.7.30 and 0.7.29 on the 1080p Pinebook
But I can't login to the main desktop
The password looks right but after submitted the password the screen went black and then back to the login page.
The LXDE 0.7.28 works.
(11-08-2018, 03:28 AM)KentChiang Wrote: I've tried the LXDE 0.7.30 and 0.7.29 on the 1080p Pinebook
Known issue. Keep in mind that 0.7.30 are pre-releases and may be completely broken. The Mate version works nicely.
  DietPi OS for Pinebook MichaIng 3 5,418 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 61,211 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 914 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 700 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,688 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,236 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,887 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,269 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,826 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,809 12-25-2020, 04:40 PM
Last Post: ford442
