Pine A64+ won't boot?
#51
After many tries I was able to boot RemixOS and Android on my Pine64.
The only procedure that worked for me was to write the images with PhoenixCard on Windows.
Just follow the instructions from the Michael Larson's video:
https://youtu.be/TjJ62s5DxPc
1- Write Mode: Startup
2- Format to Normal
3- Burn
It seems that those OS images need some special treatment.
Cons:
- If you connect the ethernet cable with RemixOS it crashes.
- Even if you have a serial console attached the system won't post anything unless it finds uboot on the sdcard.
The Ubuntu image burned with ApplePi Baker worked flawlessly.
  Bliss OS (PINE A64(+)) pineadmin 4 14,476 06-07-2019, 09:01 PM
Last Post: nukedawg
  Android 7.1 (PINE A64(+)) pineadmin 59 128,464 02-10-2019, 07:44 PM
Last Post: mmmarcus
  Pine 64 + WIFI - OVERHEAT problem Berkut 0 4,002 10-24-2018, 12:52 PM
Last Post: Berkut
  Pine64+ 1G and Pine LCD with Android 6.0.1 Tanveer 0 5,664 09-03-2018, 05:05 AM
Last Post: Tanveer
  [PINE A64 2GB Kickstarter]How to boot android from external SSD v1n1c1uS 1 4,345 01-15-2018, 11:05 PM
  Kickstarter edition wont boot to android bilbo6209 1 4,282 01-09-2018, 08:03 PM
  Bliss OS - Pine a64+ rwaterspf1 8 15,227 10-09-2017, 05:46 PM
Last Post: jkmooney
  Boot hangs on pine64, how to debug? olh 1 4,495 08-29-2017, 12:04 AM
  Android Oreo on Pine LCD Tanveer 1 4,249 08-28-2017, 07:01 AM
Last Post: ayufan
  Pine64+ 1G: boot loader details required Tanveer 4 8,731 07-29-2017, 09:07 PM
Last Post: Tanveer
