Otterbox case for PinePhone
FYI for those looking for an Otterbox case that fits the PinePhone, here is the one I found that fits very well.
OtterBox uniVERSE Case for Samsung Galaxy XCover Pro
I will need to trim out for the camera, and it needs a small trim for the small button the side.
Other than those modifications needed, it fits like a glove (when I pulled it out the back cover started coming off). And it has good screen protection.
[Image: %24_57.PNG?set_id=880000500F]
Oh nice find! I've long been looking for a case for the Pinephone that actually works and protects the screen.
So you cut a spot for the powerkey..
Do the volume keys work through the case's buttons?
(11-15-2022, 05:51 PM)mil Wrote: Oh nice find! I've long been looking for a case for the Pinephone that actually works and protects the screen.
Yup I trimmed for the power key, didn't take much and is hardly noticeable.  I used the back plate to trace where the camera lens goes, but still need to Dremel it out because the case is layered plastic and rubber.
Volume keys work perfectly through the case's buttons.
Awesome - i just got the case too and confirm it fits perfectly as well.
Volume keys just work, and for me the powerkey is exposed and didn't need any trimming at all. I just put the phone in and am set.
Back camera will need some work with dremel or exacto knife but other then that this works great OOTB.
Pretty neat. I almost never use the camera and probably wouldn't bother cutting a hole for it. I don't see any perforations for the speaker in the Otterbox, does it muffle the Pinephone speaker?
(11-18-2022, 04:00 PM)Zebulon Walton Wrote: Pretty neat. I almost never use the camera and probably wouldn't bother cutting a hole for it. I don't see any perforations for the speaker in the Otterbox, does it muffle the Pinephone speaker?
I haven't tested the speaker, I suspect it would muffle it. I will follow up when I get voice service working or test it with some music when I get a chance.
  Case for Pinephone totilele 13 7,468 04-11-2024, 11:48 AM
Last Post: gramonyl
  Slip/Zippered Case for PP/KB? jakfish 0 293 03-03-2024, 04:55 PM
Last Post: jakfish
  keyboard case charging but not typing new2pinephone 18 5,918 02-19-2024, 07:30 AM
Last Post: theResonant
  PinePhone Dock with laptop? Mikey1977Y2J 2 658 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,251 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 464 10-22-2023, 03:39 PM
Last Post: rotwang
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 533 10-21-2023, 07:50 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,044 10-20-2023, 04:11 PM
Last Post: mburns
  Getting all keys working on pine phone keyboard-case undata 5 2,521 10-08-2023, 12:19 PM
Last Post: mburns
  Mouse for the PinePhone? Peter Gamma 21 15,547 10-04-2023, 10:24 AM
