Sound completely gone with Mobian in Phone Call configuration
Since a few weeks I have problems again with call audio in Mobian. I don't use my PPP for calls often so I cannot say when the problem started.
In the settings app the sound test works fine in the "Default" configuration but fails to play any sound when set to "Phone call".
I have flashed the current weekly image and had the same problem there. So no funny configs on my side I guess.
Also I tried restarting pulseaudio, pipewire etc. as was mentioned in other threads.
OK the latest version works now.
Should have tested actually calling someone. The test in the settings app fails but calling works.
That is good to hear.
Are you getting good quality sound?  And if so are you changing any settings to get it?  My sound quality is poor for sound going out from the phone.
I am using mobian, the latest release with an apt-get upgrade.
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 16 2,167 04-28-2024, 01:52 AM
Last Post: diederik
  Pine Phone Pro audio on phone calls: discussion, support and tips apink 42 12,916 12-26-2023, 02:14 PM
Last Post: apink
  Disable the GDM service in Mobian. mburns 0 477 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 915 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 510 11-07-2023, 10:01 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 732 11-07-2023, 09:44 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 614 10-14-2023, 11:57 AM
Last Post: mburns
  Guide to Suitable Phone State Borealid 19 10,897 09-18-2023, 07:00 AM
Last Post: robocone
  Mobian libnotify custom notifications MadameMalady 5 1,446 08-01-2023, 08:51 AM
Last Post: MadameMalady
  Mobian .desktop file creation MadameMalady 15 3,303 07-27-2023, 04:12 PM
