Keyboard case is slick
I was wondering if there is anything that can be added to the keyboard case to make it less slick? I feel like every time I grab it I am going to drop it. Any ideas?
(02-25-2022, 09:06 AM)ragreenburg Wrote: I was wondering if there is anything that can be added to the keyboard case to make it less slick? I feel like every time I grab it I am going to drop it. Any ideas?
I would recommend applying a textured skin of some sort to the backside. I haven't done it yet, but added a Dbrand skin to the back of my F(x) Tec Pro1, which was also slick, and it worked wonderfully (they have a black Mat skins). There are also various ways you can make your own for much cheaper, but I like Dbrand skins.
Thanks for the help! Those look very promising!
What about using a spray-on rubber (or similar) product? You could coat the case with a light dusting of it, which should help. I haven't tried this myself, mind you.
https://www.globalshop.com.au/products/flex-seal
For byte-sized tech and software tips check out my Danimations Digital Media tips channel on Youtube Big Grin
I'm really sorry to hear that it sounds like the keyboard case is just as slick as the original case.  Sad
That's a real problem, especially since the screen is not gorilla glass, and these are made in such small numbers that no good (sturdy, like OtterBox) cases are made for them.
I have been very careful, however the inevitable happened and the phone slipped from my hand and shattered the screen, even though it was only a couple foot drop.  But I feel really bad for Mil, who has a thread (about cases) where he said he has replaced his screen 3 times already.  :o
(03-02-2022, 10:34 PM)danimations Wrote: What about using a spray-on rubber (or similar) product? You could coat the case with a light dusting of it, which should help.
The case is so slick, I was wondering if that would even adhere.  Probably best to scuff it up first a bit with some sandpaper I guess.  I guess 'ruining' it no longer matters if you are going to be spraying something like that on there anyway.
Cheers,
TRS-80
Protocols, not Platforms
You could also use something like Sugru to add non-slip areas and corner bumpers.
(03-07-2022, 07:19 AM)wibble Wrote: You could also use something like Sugru to add non-slip areas and corner bumpers.
With careful measurements a .stl file for 3D printing would be pretty easy, then post the required files and either print it yourself or send the .stl to a print as a service place.  I assume a good % of users of pinephone vs normal phones have access to this tech?
Once people have one or two designs to ruggedize the Pinephone/KB cover we can start discussions of the survival of the fittest and it seems that Pine64 has experience managing a supply chain including injection molded plastics so it would probably become a store item vs DIY printing.
For 3D modelling purposes a very accurate 3D model would make subtracting that shape from a ruggedized case prototupe design becomes easy.
  Case for Pinephone totilele 13 7,717 04-11-2024, 11:48 AM
Last Post: gramonyl
  Slip/Zippered Case for PP/KB? jakfish 0 315 03-03-2024, 04:55 PM
Last Post: jakfish
  keyboard case charging but not typing new2pinephone 18 6,055 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 11,257 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 460 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,325 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 483 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,311 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 554 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 652 10-21-2023, 02:55 AM
