Automate checking whether the Pinecil is still in stock
Big Grin
Here is a quick way to see whether the Pinecil gets back in stock.
I've been meaning to get one, but it is out of stock. To automate my stalking of pine's website, i've written this python script and thought that I could share it if someone thinks that it's neat:
import requests as r
from tkinter import messagebox as m
import tkinter as tk
import os
url = "https://pine64.com/product/pinecil-smart-mini-portable-soldering-iron/?v=0446c16e2e66"
#don't show a main window
root = tk.Tk()
root.withdraw()
response = r.get(url)
source = response.text
startIndex = source.find("<title>")
endIndex = source.find("</title>")
if (startIndex == -1) or (endIndex == -1):
    m.showerror(title="could not check pine64.com", message="please check your internet connection")
    quit()
if("[Out of Stock]" in source[startIndex:endIndex]):
    print(source[startIndex:endIndex])
    m.showinfo(title="OUT OF STOCK", message="the Pinecil is stil out of stock, unfortunately")
else:
    choice = m.askquestion(title="IN STOCK", message="THE PINECIL IS BACK\nGo to the store?")
    if choice == 'yes':
        os.system("firefox "+url)
This will show the following when executed
https://ibb.co/XzLBd1P
https://ibb.co/XCcJb9D
the only thing left then is to add a menu item with the command:
python ~/checkPinecil.py
(replace "~/checkPinecil" with the path to your saved file)
Then you can easily check whether it is available Smile
P.s. I am aware of how useless this is, but I was bored and this is the result.
Best Regards, Julius
haha! this is awesome. i'd happily alter that and point people to it for the pbp, tab, and phone, too Big Grin
Hi. I'm not a python programmer. But I made a couple of small changes for Linux.
up the top put the following for direct execution. Assuming that's where you can find your python
#!/usr/bin/python3
and this down the bottom. replacing firefox with xdg-open to be a little more generic:
os.system("xdg-open "+url)
In my case it opens a tab in chromium because it's my default browser.
don't forget to chmod +x checkPinecil.py if you want to run the file directly.
e: Thanks again for posting. I just got the basics of your program running in MicroPython on an eap32. So I now have the basis of a standalone in-stock alert.
(02-01-2021, 08:45 PM)ImmortanJoe Wrote:
#!/usr/bin/python3
Those are good changes, I didn't really give machine independence a lot of thought when I wrote it.
I'm glad that this could serve as a basis, your project sounds really cool
Any rumor as to when the next will go on sale?
(01-27-2021, 02:15 PM)Julius_GU Wrote: Here is a quick way to see whether the Pinecil gets back in stock.
import os
root = tk.Tk()
root.withdraw()
    quit()
else:
    if choice == 'yes':
updated it so it also knows if something will be back soon also any browser will work now
import webbrowser as web
import os
root = tk.Tk()
root.withdraw()
    quit()
elif("[Schedule back in stock " in source[startIndex:endIndex]):
    m.showinfo(title="OUT OF STOCK", message="the Pinecil is scheduled to be back in stock")
else:
    if choice == 'yes':
        web.open(url, new=0, autoraise=True)
Question Can Pinecil Read USB-C Cable E-Marker Chips? Garywoo 0 36 04-23-2024, 01:48 PM
Last Post: Garywoo
  Connecting a power supply to the Pinecil jon_bondy 1 394 02-29-2024, 07:37 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 804 01-31-2024, 12:34 AM
Last Post: suga7
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 380 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 8,327 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 679 11-02-2023, 09:11 AM
Last Post: Harrysteed
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,308 10-09-2023, 10:10 PM
Last Post: clemon79
  PD resets during heat up tip [Pinecil V2] Neitron4ik 2 1,560 10-09-2023, 01:22 AM
Last Post: Neitron4ik
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,463 02-02-2023, 11:45 AM
Last Post: VaZso
  Brand new Pinecil v2 won't boot on PD jhutch 1 2,266 12-14-2022, 01:03 AM
Last Post: River
