PineBook Docking Deck charging port?
Piners,
I recently got the PineBook Pro USB-C Docking Deck and think it's really great!  I watched the great first review video mentioned in the last update and it was great.  The video is the only place where I found mentioned which port to plug my charge into so that it delivers it to the PBP.  The video states that it is the lone USB-C port on one side and not the 2 together on the other side.
Something seems wrong.  Here is my experience.
Port 1 does not provide any charging.  Ports 2 and 3 do but may not be enough. (see attached images)
So on my deck only ports 2 and 3 say charging.  However, I believe that they might not be providing enough power to really charge the PBP.  I'm checking that now by charging through the Dock while doing nothing on the PBP.  It's just sitting there without any apps running or windows open.
ColoBill
The usb-c port closest to the cable end accepts charge to power my pinephone. I think there was something on twitter about the pinebookpro and a software update to support the deck.
(01-14-2021, 06:02 PM)nas Wrote: The usb-c port closest to the cable end accepts charge to power my pinephone. I think there was something on twitter about the pinebookpro and a software update to support the deck.
Same here, screen brightness starts to flicker high and low and is pretty annoying. I would be glad for a solution ;D
I am starting to using the deck yesterday, got it working for me the night before. And the HDMI stopped working that but then works again and works fine for me the whole working day.
Anyway, when I first received the deck, it's doing the screen flicker thing for me, but not anymore for me, and the HDMI doesn't works for me at all so I sort of give up the idea to use it or a month or two.
So I am using the lone USB C port next to the HDMI port and it is charging fine as the indicate in the notification bar.
Either the deck is having quality control issue or the software need to be stabilised, seems I am not the only one have trouble to figure out how to make the deck working.
And the manual provided is unfortunately not very helpful as well.
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 529 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 331 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 274 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 609 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,077 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 130,004 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 5,991 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,405 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 135,345 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,888 10-21-2022, 07:57 AM
Last Post: dachalife
