OpenMandriva to release ARM builds for PineBook Pro and Pi
Err, perhaps you know, or perhaps not,,, every compressed file, zip, gz, xz whatever
is pretty much --self-checking--,, that is, if any bits flip, any at all, it will error out
Or, xz -t somefile.xz
You may know, the rk3399 will use whatever uboot it finds FIRST, likely whatever is on emmc
What is on your emmc?
thanks
(03-02-2021, 01:29 PM)wdt Wrote: Err, perhaps you know, or perhaps not,,, every compressed file, zip, gz, xz whatever
I can only say that the sha of the two files I downloaded were not the same. Hell, even the file size was not the same. They both copied to SD fine. One didn't boot, the other did. Perhaps an issue with the tool or a wrong link. Might have been an old cache in an sf.net mirror. I don't remember at the moment. It was a a week or two ago.
Quote:You may know, the rk3399 will use whatever uboot it finds FIRST, likely whatever is on emmc
thanks
Initially the Debian shipped with the device. Then flashed over with the Manjaro image.
I might be getting confused with another sbc, but I thought first selection was based on a jumper. (Might be thinking about my ci20 though.)
  Debian on Pinebook Pro u974615 7 1,042 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,616 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,157 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,232 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,028 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,249 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,285 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,487 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,593 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 665 07-13-2023, 05:21 PM
Last Post: owaspfap
