06-11-2021, 05:52 AM
Also, you can put holes in your bottom cover already. I have long planned to do this. Don't know when I'll get round to it.
Would you like to see and buy the 2.2 revision? | |||
Yes, please! | 55 | ||
No, thank you | 5 | ||
60 vote(s) |
* You voted for this item. | [Show Results] |
PineBook Pro revision 2.2: Wishlist for the hardware issue fixes
06-11-2021, 06:02 AM
(This post was last modified: 06-11-2021, 06:03 AM by dsimic.
Edit Reason: Word choice
That's a very good point! The only issue could be the rather long distance between the PCB and the back cover, which would make it a bit hard to accurately poke the buttons using a pin or something similar, without accidentally touching something else on the PCB. The buttons should be much closer to the back cover for the pinholes to work safely.
06-12-2021, 04:05 AM
(06-11-2021, 06:02 AM)dsimic Wrote: That's a very good point! The only issue could be the rather long distance between the PCB and the back cover, which would make it a bit hard to accurately poke the buttons using a pin or something similar, without accidentally touching something else on the PCB. The buttons should be much closer to the back cover for the pinholes to work safely.That is why the toothpick in our knife is non-conductive.
07-07-2021, 07:35 PM
(06-12-2021, 04:05 AM)KC9UDX Wrote:(06-11-2021, 06:02 AM)dsimic Wrote: That's a very good point! The only issue could be the rather long distance between the PCB and the back cover, which would make it a bit hard to accurately poke the buttons using a pin or something similar, without accidentally touching something else on the PCB. The buttons should be much closer to the back cover for the pinholes to work safely. After removing the back cover of my ISO PineBook Pro a couple of times to use the switch that disables the eMMC module, your suggestion about drilling a few holes in the bottom cover seems increasingly more reasonable.
07-07-2021, 10:29 PM
(07-07-2021, 07:35 PM)dsimic Wrote:(06-12-2021, 04:05 AM)KC9UDX Wrote:(06-11-2021, 06:02 AM)dsimic Wrote: That's a very good point! The only issue could be the rather long distance between the PCB and the back cover, which would make it a bit hard to accurately poke the buttons using a pin or something similar, without accidentally touching something else on the PCB. The buttons should be much closer to the back cover for the pinholes to work safely. If n is the number of times the cover gets taken off before I get annoyed enough to drill the holes, I must be at n-1
:wq
[ SRA accepts you ]
07-09-2021, 02:46 PM
(This post was last modified: 07-09-2021, 02:48 PM by dsimic.
Edit Reason: Better wording
Another nice-to-have feature in the next revision of PineBook Pro would be inclusion of the "SPI disable" switch on the main board, similarly to the already existing "eMMC disable" switch. That would make debugging and recovery of SPI U-Boot installations a lot easier.
07-10-2021, 12:14 AM
Post 11
On topic, how about small holes over emmc and serial switches, with flush rubber plugs? There is a button, to short SPI clock, unfortunetly not very reliable Maybe needs a 'wiggle' press? (but, if you are not sure that what is about to be flashed (to SPI) is not 99% likely to be good, DON'T do it)
07-10-2021, 06:58 AM
This machine should be the kind where you can find out if the software is good by trial.
That button should be a switch, and all the switches should be accessible without removing the bottom cover.
:wq
[ SRA accepts you ]
07-13-2021, 08:36 PM
(06-12-2021, 04:05 AM)KC9UDX Wrote:instead of tiny holes for "toothpick" access to the emmc switch maybe square inch access port cut out and a screw in cover plate like a lot of laptops have for their ram and drive access? ..not so new of an(06-11-2021, 06:02 AM)dsimic Wrote: That's a very good point! The only issue could be the rather long distance between the PCB and the back cover, which would make it a bit hard to accurately poke the buttons using a pin or something similar, without accidentally touching something else on the PCB. The buttons should be much closer to the back cover for the pinholes to work safely.That is why the toothpick in our knife is non-conductive.
07-13-2021, 10:48 PM
Cover plus screws is a good idea but costly compared to small holes with rubber plugs.
It would be handy to be able to replace the eMMC without taking the bottom off, though, wouldn't it?
:wq
[ SRA accepts you ] |
HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? | segaloco | 4 | 737 |
05-06-2024, 09:27 AM Last Post: KC9UDX |
New Hardware | names_mark_ | 1 | 258 |
04-23-2024, 08:41 AM Last Post: dachalife |
Pinebook Pro on Debian 12 Power Issue | u974615 | 1 | 378 |
03-13-2024, 10:46 AM Last Post: u974615 |
Pinebook Pro Source for Trackpad Flex / Ribbon Cable | rankharris | 1 | 325 |
02-17-2024, 07:06 PM Last Post: tllim |
Pine Dock Networking Issue | trillobite | 1 | 305 |
02-10-2024, 12:03 AM Last Post: trillobite |
Pinebook Pro charging issues | tomekdev | 1 | 661 |
01-05-2024, 08:40 PM Last Post: tomekdev |
Replacement battery for PineBook Pro | DrYak | 3 | 1,165 |
11-07-2023, 10:09 AM Last Post: DrYak |
Pinebook Pro Revised Keyboard Firmware | jackhumbert | 73 | 131,691 |
09-13-2023, 03:43 AM Last Post: k3dAR |
Hardware makes a strange pop noise. | Gemeindepirat | 7 | 3,092 |
08-12-2023, 01:59 AM Last Post: User 27258 |
PineBook Pro dead | ottahe | 9 | 6,142 |
01-18-2023, 07:41 PM Last Post: ottahe |
