Curious about problem with PBP Wifi
This is not a problem per se with PBP.  Recently my ISP's modem has been acting up and I'm waiting on a new one.  Before it started acting up, PBP connected to wifi just fine, but now it won't connect.  Curiously, my Android based smartphone connects fine, as does an 8 year old Lenovo ThinkPad.  I've been trying to share the connection with the smartphone via bluetooth with less than perfect results.  The old Lenovo is running Fedora 32 and this PBP Fedora 33.  Perhaps I should mention, though irrelevant to the PBP that ethernet hardly works at all.
With inxi I just get
inxi -N
Network:
  Message: No ARM data found for this
which doesn't give me a whole lot of info to work with.
Hopefully soon my ISP will fix the situation but I'm curious.  My question is, why would the PBP not be able to connect to wifi while the smartphone and old laptop can?  Is there a remedy?
Kendew
We have a WiFi trouble shooting section on the Wiki. Give it a look:
Wiki - Pinebook Pro - Troubleshooting Guide - WiFi issues
As usual, feel free to correct, improve or comment, (good or politely bad).
Arwen Evenstar
Princess of Rivendale
Similar question.  Is the PBP just not 'real good' in terms of wifi range?  At the one corner of my house, PBP is intermittent with wifi, but my MacBook and iPhone are rock solid.  A few feet 'closer' and the PBP seems to be 'better'.  Is this normal?
(01-14-2021, 10:56 AM)tkudog Wrote: Similar question.  Is the PBP just not 'real good' in terms of wifi range?  At the one corner of my house, PBP is intermittent with wifi, but my MacBook and iPhone are rock solid.  A few feet 'closer' and the PBP seems to be 'better'.  Is this normal?
Pinebook Pros use mediocre stock hardware (card itself and antenna) plus mediocre firmware. Will this get fixed in the future with the work currently being done on the nutcracker challenge? maybe.
Most laptops, like MacBooks, use a pair of antennas up in the display assembly. Pinebook Pros, however, have a single antenna in the main body. On top of that, it is theorized that the magnesium body of the PBP noticeably weakens the signal coming through to the antenna.
tl;dr PBP wifi is far from optimal, and many people report bad signal strength.
  Yet another new Pinebook keyboard problem MikoBob 3 846 09-11-2024, 07:05 AM
Last Post: MikoBob
  Kernel Not Detecting Wifi tallfrye 10 3,254 01-01-2024, 06:57 AM
  Problem with USB 3.0 Type A hobbitus 4 2,404 07-15-2023, 11:14 AM
Last Post: dachalife
  Connection to WiFi with OWE IhorOlkhovskyi 1 1,982 09-01-2022, 08:48 AM
Last Post: IhorOlkhovskyi
  Is there a way to turn off Wifi completely? jirow 10 10,705 06-20-2022, 05:53 AM
Last Post: Kaythe
  RTL8811AU usb wifi for pbpro vlut 0 1,649 12-02-2021, 05:23 AM
Last Post: vlut
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 3,050 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  Wifi disconnecting after few minutes hellojack 0 1,740 09-16-2021, 02:50 AM
Last Post: hellojack
  Advice on increasing WIFI range stozi 2 4,852 03-29-2021, 06:57 AM
Last Post: barray
  Privacy switches - cutting power to wifi card as400 1 3,382 08-10-2020, 09:48 AM
Last Post: belfastraven
