05-13-2021, 08:43 AM
If you get a chance then report the problems on github to try to get it fixed.
Anyone been able to get a working GloDroid img on SD?
05-13-2021, 09:33 AM
hopefully whenever the next batch of the tabs can be made they are still similar enough to the EA version, and we can put one in rsglobal's hands. that'll certainly beat them trying to help us blindly lol
05-26-2021, 01:09 PM
as of v0.6.1, the screen works on Glodroid+Pinetab! yay! physical keyboard works great, wifi, and bt, too. Only thing I'm noticing a lack of is display orientation/rotation.
05-29-2021, 01:45 PM
(05-26-2021, 01:09 PM)tophneal Wrote: as of v0.6.1, the screen works on Glodroid+Pinetab! yay! physical keyboard works great, wifi, and bt, too. Only thing I'm noticing a lack of is display orientation/rotation.I flashed the image on sdcard. If i press on Bluetooth, it's crashing. The sound is also not working. Is it better to flash on emmc?
06-01-2021, 08:46 AM
(05-29-2021, 01:45 PM)m.alizade7 Wrote: I flashed the image on sdcard. If i press on Bluetooth, it's crashing. The sound is also not working. Is it better to flash on emmc? unfortunately, i cannot say. i alway run into issues trying to get the standard build scripts to build the images. I used the gensdimg.sh script and am running glodriod from an SD |
Working OS on pinetab RISC-V? | user641 | 3 | 943 |
12-13-2023, 08:11 AM Last Post: tophneal |
Udemy not working on pinetab2 (danctnix) | jbreese | 3 | 1,196 |
06-13-2023, 11:34 AM Last Post: jbreese |
Important apps stopped working | yurievitch | 2 | 4,546 |
07-14-2021, 11:43 PM Last Post: LisaFord |
Got Vivaldi Working on Arch! | wd5gnr | 3 | 6,513 |
11-09-2020, 12:13 PM Last Post: hanscees |
