openSUSE for Pinephone
#71
(11-27-2021, 08:31 AM)flembcke Wrote: I have finally installed Posh on my pinephone.
Everything seems to work right.
Rotation is upside down, any tips on how to fix it?
Telegram can not receive the code. Any ideas how to make it work?
Do you mean you aren't receiving the SMS code from Telegram? If so, that has happened every time I set it up on the PP. I would recommend having an account on your desktop then instead of sending an SMS (which never comes through), it will send a code to the other Telegram client.
Thanks for the reply.
it does not seem much maintained ;(
I tried but autorotate turns the screen 90° to the left of what it should, and connection to nextcloud failed somehow.
Had the same issue with Telegram (on Manjaro Phosh, but it looked and did the same on Mobian or some other as well), and the point is that it's near impossible to create a new account without an old one. It just won't send the verification code as a SMS, it sends to an existing Telegram instance. So creating it with my phone didn't work, wife's didn't work (no Telegram either), daughter's did (has Telegram). But then I had her identity.
So I had to create a new account within this clone of her identity, which meant another security code. Nice touch is that this time I didn't have to retype it, the confirmation went instantaneously and I was finally me. Daughter was also me for a while... Then repeated the process for my desktop (repeated me, on Mint) and wife's laptop (also Mint, separate account). That works.
Daughter also had to do something on her Telegram to make sure she's not me and to revert to her original account.
So it won't grow from seeds, only by cloning and then identity change.
OpenSuse seems a tad more reliable with plasma mobile, compated with Manjaro, which is currently not working well. However, after update, there is not enough kernel allocated memory or it will not boot at all ;(
after flashing again it seems to work, even connected to nextcloud, but does not show any contacts. Very nice to watch boot or update in verbose.
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 234 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Movuan distribution for PinePhone merom 4 1,017 04-07-2025, 12:32 AM
  Latest firmware for PinePhone modem! Subsentient 105 175,181 02-02-2025, 08:47 PM
Last Post: bacydentir85
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 43,284 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 1,450 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 47,140 07-26-2024, 10:35 PM
  Why does Pine64 sabotage office on the Pinephone? Peter Gamma 5 2,461 07-04-2024, 07:34 AM
  Which word processor to choose for the Pinephone? Peter Gamma 16 9,604 06-22-2024, 07:28 AM
  Samba share on the Pinephone? Peter Gamma 0 1,143 06-16-2024, 10:26 PM
  Possible Free Backup Carrier for PinePhone PineFone 0 1,072 06-13-2024, 03:45 PM
Last Post: PineFone
