Pinebook Pro not Booting at All eMMC or MicroSD
#21
@tophneal
#22
(07-13-2020, 06:12 PM)AstroCEO Wrote: It just blinks orange and does absolutely nothing with eMMC switch disabled, or even with it removed entirely.  It only boots period with eMMC attached.
My guess would be that uboot on SPI isn't being used, or may not have flashed successfully, then. Without or without the emmc it should be able to boot SD or USB first.
If emmc is installed and you insert a bootable SD, what does it do?
  Debian on Pinebook Pro u974615 7 1,252 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,759 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,220 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,307 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,749 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 439 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,305 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,458 08-31-2023, 04:20 PM
Last Post: TRS-80
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,011 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 996 08-18-2023, 01:58 AM
Last Post: juliamenendez
